MQTT payload works but Functions not working
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
#include "certs.h"
const char* mqtt_server = "broker.mqttdashboard.com";
char messageBuffer[50];
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long currentTime;
unsigned long startTime;
unsigned long period = 1000;
bool power = false;
void setup_wifi()
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  if (!client.connected())
    reconnect();
  client.loop();
  if (power == true)
    RainbowEffect();
void reconnect()
  while (!client.connected())
    if (client.connect("Reception"))
      Serial.println("connected");
      client.subscribe("RGB/Output");
    else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void callback(char* topic, byte* payload, unsigned int length)
  //Serial.println();
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  Serial.print("length : ");
  Serial.println(length);
  memcpy(messageBuffer, payload, length);
  messageBuffer[length] = '\0';
  Serial.print("the payload is : ");
  Serial.println(messageBuffer);
  if (strcmp(messageBuffer, "on") == 0)
      Serial.print("turning ");
      digitalWrite(LED_BUILTIN, LOW);
      power = true; //activate rainbow
  else if (strcmp(messageBuffer, "off") == 0)
      digitalWrite(LED_BUILTIN, HIGH);
      OffRainbow();
      power = false;  //stop the rainbow
void OffRainbow()
  Serial.print("RainbowOff");
void RainbowEffect()
  currentTime = millis();
  if (currentTime - startTime >= period)
    Serial.print("RainbowOn");
    startTime = currentTime;
Code can show payloads in Serial, but
      OffRainbow();
not working
What do you see if you print the result of the strcmp() ?
I have used something similar to your code, the only difference being that my equivalent of messageBuffer is declared as a pointer
What does your serial output look like?
  Serial.print("] ");
Serial output is like payload is on/off. basically the code above whenever I give command on mqtt box.
I really wanted to see the actual output from the serial monitor. I note that you have wisely included some square brackets so it's possible to detect newlines or spaces so I wondered whether the payload does contain such things.
What are you using to send the payload ?
MQTTBox maybe ?
What settings are you using ?
I have just tested your code using MQTTBox and a Wemos D1 mini ESP8266 and it works for me
MQTT Box. What settings are you referring to?
QoS, Retain and Payload Type
I took a screenshot the Qos, Retain and Payload type
That looks the same as my setup apart from the fact that I have Retain selected but as you are getting payloads that would not seem to be a problem.
Some things to try to help track down the problem
1 - print strlen(messageBuffer) after printing messageBuffer in callback()
2 - print each element of messageBuffer individually
for (int c = 0; c < strlen(messagBuffer); c++)
  Serial.print(messageBuffer[c]);
3 - print what is returned by strcmp(messageBuffer, "on") and strcmp(messageBuffer, "off")
  //Serial.println();
  Serial.print("] ");
  Serial.print(strlen(messageBuffer));
  for (int c = 0; c < strlen(messageBuffer); c++)
Serial.println(strcmp(messageBuffer, "on"));
Serial.println(strcmp(messageBuffer, "off"));
      OffRainbow();
Like this?
This is what I got from the serial monitor
failed, rc=-2 try again
So you're not getting a connection to the broker. Have you ever done so?
None of that printout came from the callback function. As suggested, it looks like you did not get a connection to the broker
wildbill:
Before adding the additional stuff it was able to connect just fine
Do you have a copy of the old one to test?
As I previous said the code in the original post works for me
Are you sure that the 8266 is connecting to your wireless router ?
hmmm its weird now it doesn't connect
#include "certs.h"
bool power = false;
void setup_wifi()
  Serial.println("");
  setup_wifi();
    reconnect();
  client.loop();
  if (power == true)
    RainbowEffect();
void reconnect()
    else {
      Serial.println(" try again");
  //Serial.println();
  Serial.print("] ");
      OffRainbow();
void OffRainbow()
Try this
void setup_wifi()
  Serial.print("connecting to ");
  Serial.println(SSID);
  WiFi.begin(SSID, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.print("WiFi connected to ");
  Serial.print("IP address : ");
  delay(2000);
Unlike your version it does not just blindly assume that WiFi has been connected
ok it connects
WiFi connected to ASUS
IP address : 192.168.1.88
connected
Message arrived [RGB/Output] length : 6
the payload is : off
off
Message arrived [RGB/Output] length : 5
the payload is : on
on
This is what I got from the Serial
  //Serial.println();
  Serial.print("] ");
      OffRainbow();
So, there's three extra characters in the payload. Most likely CR and LF in some combination by the look of the output.
What's the sending side passing to MQTT?
