Zuhause, da konnte ich besser auf die Pirsch nach dem Fehler gehen.
So kompiliert es Fehlerfrei:
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <PubSubClient.h>
#include <EEPROM.h>
#include <ArduinoJson.h>
/* ------------------------ Change Me --------------------------------------- */
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "";
const char* mqtt_username = "";
const char* mqtt_password = "";
bool use_fahrenheit = false;
#ifdef DEBUG_FLAG
#define debug(x) Serial.print(x)
#define debugln(x) Serial.println(x)
#else
#define debug(x)
#define debugln(x)
#endif
/*--------------------------ADDED IN----------------------------------*/
unsigned long previousMillis = 0;
unsigned long interval = 30000;
/* ------------------------ Messages --------------------------------------- */
#define MESH_ID 6734922
typedef struct struct_message {
int mesh_id;
int id;
char state[7];
int vBatt;
float Temp;
} struct_message;
struct_message myData;
//struct_message msg;
uint8_t incomingData[sizeof(struct struct_message)];
size_t received_msg_length;
/* --------------------------- Wifi/MQTT ---------------------------------------------- */
WiFiClient wifiClient;
char mqttTopic[200]; //<- Anpassen auf die maximale Länge
char mqttPayload[100]; //<- Anpassen auf die maximale Länge
const char* baseTopic = "Fensterkontakte/Fenster.";
const char* idTopic = "/ID";
const char* stateTopic = "/Zustand";
const char* batterieTopic = "/Batterie";
const char* tempTopic = "/Temperatur";
#define MSG_BUFFER_SIZE (50)
PubSubClient mqttClient(wifiClient);
void initWiFi() {
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
WiFi.setAutoReconnect(true);
WiFi.persistent(true);
Serial.print("Connecting to WiFi ..");
Serial.print('.');
/* ############################ Setup ############################################ */
initWiFi();
Serial.print("RRSI: ");
Serial.println(WiFi.RSSI());
mqttClient.setServer(mqtt_server, 1886);
String MAC = WiFi.macAddress();
MAC.replace(":", "");
/* ############################ Loop ############################################# */
wifiReconnect();
mqttReconnect();
mqttClient.loop();
if (Serial.available()) {
received_msg_length = Serial.readBytesUntil('\n', incomingData, sizeof(incomingData));
if (received_msg_length == sizeof(incomingData)) { // got a msg from a sensor
memcpy(&myData, incomingData, sizeof(myData));
if (myData.mesh_id == MESH_ID) sensorMessageOverMQTT();
void sensorMessageOverMQTT() {
Serial.println(myData.id);
snprintf(mqttTopic, sizeof(mqttTopic), "%s%d%s", baseTopic, myData.id, idTopic);
snprintf(mqttPayload, sizeof(mqttPayload), "{\"id\":\"%.d\"}", myData.id);
mqttClient.publish(mqttTopic, mqttPayload);
Serial.println(myData.state);
snprintf(mqttTopic, sizeof(mqttTopic), "%s%d%s", baseTopic, myData.id, stateTopic);
snprintf(mqttPayload, sizeof(mqttPayload), "{\"state\":\"%.s\"}", myData.state);
Serial.println(myData.vBatt);
snprintf(mqttTopic, sizeof(mqttTopic), "%s%d%s", baseTopic, myData.id, batterieTopic);
snprintf(mqttPayload, sizeof(mqttPayload), "{\"state\":\"%.d\"}", myData.vBatt);
Serial.println(myData.Temp);
snprintf(mqttTopic, sizeof(mqttTopic), "%s%d%s", baseTopic, myData.id, tempTopic);
snprintf(mqttPayload, sizeof(mqttPayload), "{\"state\":\"%.f\"}", myData.Temp);
/* ################################# MQTT ########################################### */
void mqttPublish(String topic, String message) {
Serial.println("Publish");
if (!mqttClient.connected()) {
mqttReconnect();
mqttClient.publish(topic.c_str(), message.c_str());
void mqttReconnect() {
Serial.println("Waiting for ESP-NOW Message");
while (!mqttClient.connected()) {
Serial.print("Attempting MQTT connection...");
String clientId = "ESP-NOW-Board-";
clientId += String(myData.id);
if (mqttClient.connect(clientId.c_str(), mqtt_username, mqtt_password)) {
Serial.println("connected");
Serial.print("failed to connect to mqtt server, rc = ");
Serial.print(mqttClient.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
/* ############################ ADDED THIS - SEE LOOP ############################################# */
void wifiReconnect() {
// if WiFi is down, try reconnecting every CHECK_WIFI_TIME seconds
if ((WiFi.status() != WL_CONNECTED) && (currentMillis - previousMillis >= interval)) {
Serial.print(millis());
Serial.println("Reconnecting to WiFi...");
WiFi.disconnect();
// WiFi.config(localIP, gateway, subnet, primaryDNS); //////////////////////////////////////////////// added on 11/15
//Alternatively, you can restart your board
//ESP.restart(); /////////////////////////////////////////////////////////////////////////////////added back in 11/15
Grundübel war ein #define.
#define char mqttTopic[200]; //<- Anpassen auf die maximale Länge
Warum fügst du dort ein #define ein? Macht keinen Sinn.
#define ist eine Präprozesordirektive. Also eine reine Textersetzung, bevor der Compiler kompiliert.
Gefolgt von ein paar Schreibfehlern, die du wahrscheinlich auch selber noch gefunden hättest. (mqttclient -> mqttClient);
Ein paar Warnungen zur Zuweisung vom falschen Typ.
Und das Handmade JSON hatte ein " an einer falschen Stelle. Ich sagte ja, fehleranfällig. Dafür gibt es eine schöne Bibliothek.
