hi, for my HNC in electrical engineering i am undertaking a project to create a multi probe ph meter for a lithographic printing press, where each probe will have its own display reading pH level and temperature in real time.
each print unit (each colour) has a dampening tray where the solutions pH can vary with ink contamination and calcium build up - leading to print problems.
i have a few questions regarding this project as i have no idea about using arduino or programming....so any help would be massively appreciated.
would an arduino uno be powerful enough to run 5x ph probes and 5xOLED displays?
has anyone had any experience of making a multi ph probe that could advise me of any pitfalls?
again, any help with this would be massively appreciated.
hi Jim, i think some pH probes offer the ability to record temperature as well, for the point of my project, temperature isnt critical but is for bonus points.
real time - its only really to give the machine operator a visual figure to see if there is any chemical imbalance causing their print issues - to lower printed waste.
this is another way i could go, luckily i dont have to physically make the product, its more the design aspect - however, i do need to provide evidence of code and a circuit diagram.
i'm open to any ideas of components as i am new to all this so dont really know.
Please provide hard numbers,
products need specifications to define what they can do and cannot do.
What is a chemical imbalance? is it an absolute measure? or relative?
is it linear or logarithmic (as pH itself is logarithmic)?
What and how much data should appear on the display?
Last measurement? average? a graph?
Also how many samples per minute must be made?
Probably depends on the worst case scenario how fast the pH can change?
Designing means you need to find out all those details by talking to the end users of the product.
(and that are often not the people who buy the product or pay for it).
Then find the appropriate components to meet the requirements.
a stable pH level is anywhere between 4.5 and 5.5....anything out of this may start to see print issues.
on the display, i only require the current pH level and potentially the temperature as the solution continuously circulates. the pH could alter during a run length of a job, which can vary depending on how many sheets it is.
i would need the pH reading to be taken frequently so 20 to 30 samples per minute should be adequate enough
i was using Cirkit Studio to mock up a device. i will see if i can complete that and export it to here
Are you contemplating multiple displays because they each need to be in a different location or would a single display unit with multiple lines be just as convenient?
Are the probes separated by some distance? Would there be an advantage to being able to see all the probe values in one location?
Not necessarily. If it's necessary to have each probe have its own Arduino then combining the probe values in a central display would be more complicated than if there is a central Arduino/multiline display with all the probes connected to it. It depends somewhat on the physical separation of the different ink supplies.
the probes will be away from the displays, so it wouldnt hurt to have them all on one display - i however dont know components for this, if you have some recommendations that i could investigate, that would be brilliant
Not knowing the model pH probe or what kind of signal conditioning it requires for display it's hard to go much farther but multiline OLED displays are pretty common so it would be practical to use one.
It matters how much distance between the pH probe and its conditioning circuitry can be tolerated so there may be a reason to have an Arduino associated with each probe. At this point it's mostly speculation.
ok, thanks, i will look into that and see if it is feasible to use only one arduino - is it possible to link several arduinos to one power supply so i'd only be using one power cable, as opposed to 5 (1 per arduino)
