hi,
I'm a complete newbie to all this but loving it all the same just trying to add to an existing code i found for a push button on/off circuit.
I'm able to get one relay working from one switch but I'm unsure how to add extra switches to the code.
I am able to change the input and output pins but don't know where or how to add to the code to give me more switch input and outputs
Any help would be great
Thanks in advance
this is the code I'm using
/* switch
- Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
- press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's
- a minimum delay between toggles to debounce the circuit (i.e. to ignore
- noise).
- David A. Mellis
- 21 November 2006
int inPin = 3; // the number of the input pin
int outPin = 12; // the number of the output pin
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
reading = digitalRead(inPin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
digitalWrite(outPin, state);
previous = reading;
