Multiple(at least three) force sensitive resistor setup
I'm a High school student working on an individual project, basically, I want to connect multiple(three) force-sensitive resistors and receive feedback from each of them. I have successfully managed to use a singular FSR, however, when I try to connect three, I am getting error messages in my half-written half copied code (surprise) and was wondering if anyone could help. Currently, I have two FSRs connected and both have been tested to ensure they and the wiring are working.
I am using an Arduino uno R3 board, windows 11, and the Arduino IDE software.
Any help is much appreciated.
here is the code:
#define fsrpin A0
#define fsrpin2 A1
//Define variable to store sensor readings:
int fsrreading;
int fsrreading2;
//Variable to store FSR value
// Begin serial communication at a baud rate of 9600:
// Read the FSR pin and store the output as fsrreading:
fsrreading = analogRead(fsrpin);
// Print the fsrreading in the serial monitor:
// Print the string "Analog reading = ".
Serial.print("Analog reading = ");
// Print the fsrreading:
Serial.print(fsrreading);
// We can set some threshholds to display how much pressure is roughly applied:
if (fsrreading < 10) {
Serial.println(" - No pressure");
} else if (fsrreading < 200) {
Serial.println(" - Light touch");
} else if (fsrreading < 500) {
Serial.println(" - Light squeeze");
} else if (fsrreading < 800) {
Serial.println(" - Medium squeeze");
Serial.println(" - Big squeeze");
fsrreading = analogRead(fsrpin2);
Serial.print(fsrreading2);
delay(500); //Delay 500 ms.
}   // Move this bracket to the end of the program.
consider
const byte PinFsr [] = { A0, A1, A2 };
const unsigned Nfsr = sizeof(PinFsr);
char        s [80];
const char *t;
void loop ()
    for (unsigned n = 0; n < Nfsr; n++)  {
        int fsr = analogRead (PinFsr [n]);
        if (fsr < 10)
            t = "No pressure";
        else if (fsr < 200)
            t = "Light touch";
        else if (fsr < 500)
            t = "Light squeeze";
        else if (fsr < 800)
            t = "Medium squeeze";
            t = "Big squeeze";
        sprintf (s, " %6d %-18s", fsr, t);
        Serial.print (s);
    Serial.println ();
    delay (500);
void setup ()
    Serial.begin (9600);
Thank you for the help, and I have another question do you know how to get the mass(grams)?
Calibrate your setup using some known weights, following this excellent tutorial.
