Multiple Buttons on 1 analog pin
Thought i'd share a little project i've been working on. As many may know there is a method for using a single analog pin to control multiple buttons. There is even a library for it. Problem is the way they connect the circuit doesn't allow for the use of button combinations.
So you couldn't press 2 buttons at the same time to perform a different action.
Rather then connecting the resistors in series like that i reorganized it in parallel.
Then i sorted the buttons into a directional pad configuration with 2 action buttons.
Trick was working out which resistors to use on the buttons. If the resistor values are not right then the values read by the analog pin could be too close or overlap on some combos. So here are the possible 2 button combos and values the analog pin will see when the buttons are pressed.
BUTTONS VALUES RESISTORS
btn 1 837-838 220
btn 2 737-738 390
btn 3 610-611 680
btn 4 318-319 2.2k
btn 5 178-179 4.7k
btn 6 91-92 10k
btn 1 + btn 2 896-897
btn 1 + btn 3 877-878
btn 1 + btn 4 851-852
btn 1 + btn 5 844-845
btn 1 + btn 6 840-841
btn 2 + btn 3 821-822
btn 2 + btn 4 769-770
btn 2 + btn 5 753-754
btn 2 + btn 6 745-746
btn 3 + btn 4 674-675
btn 3 + btn 5 643-644
btn 3 + btn 6 627
btn 4 + btn 5 408-409
btn 4 + btn 6 363-364
btn 5 + btn 6 243
Here is the code i put together for using the buttons in this controller configuration.
AnalogButton_Combos
Version 0.1
Connection more then one button to a single analog pin. Utilizing
software debounce to prevent registering multiple button press
while allow for 2 button combos to be registered.
The Circuit:
  Most other analog buttons circuits call for the resistors to be
  lined up in series from ground. The analog pin and each button
  connect off one of the resistors. My cuicuit requires that the
  resistors tie in from +5 to the buttons. The buttons all connect
  to the analog pin which is tied to ground threw a 1k resistor as
  seen in the diagram below.
         Analog pin 5
Ground--1K--|--------|--------|-------|-------|
           btn1     btn2     btn3    btn4    btn5
         220 Ohm  390 Ohm  680 Ohm   2.2K    4.7K
            |--------|--------|-------|-------|-- +5V
Created By: Michael Pilcher
February 24, 2010
int j = 1; // integer used in scanning the array designating column number
//2-dimensional array for asigning the buttons and there high and low values
int Button[21][3] = {{1, 837, 838}, // button 1
                     {2, 737, 738}, // button 2
                     {3, 610, 611}, // button 3
                     {4, 318, 319}, // button 4
                     {5, 178, 179}, // button 5
                     {6, 91, 92}, // button 6
                     {7, 896, 897}, // button 1 + button 2
                     {8, 877, 878}, // button 1 + button 3
                     {9, 851, 852}, // button 1 + button 4
                     {10, 844, 845}, // button 1 + button 5
                     {11, 840, 841}, // button 1 + button 6
                     {12, 821, 822}, // button 2 + button 3
                     {13, 769, 770}, // button 2 + button 4
                     {14, 753, 754}, // button 2 + button 5
                     {15, 745, 746}, // button 2 + button 6
                     {16, 674, 675}, // button 3 + button 4
                     {17, 643, 644}, // button 3 + button 5
                     {18, 627, 627}, // button 3 + button 6
                     {19, 408, 409}, // button 4 + button 5
                     {20, 363, 364}, // button 4 + button 6
                     {21, 243, 243}}; // button 5 + button 6
int analogpin = 5; // analog pin to read the buttons
int label = 0;  // for reporting the button label
int counter = 0; // how many times we have seen new value
long time = 0;  // the last time the output pin was sampled
int debounce_count = 50; // number of millis/samples to consider before declaring a debounced input
int current_state = 0;  // the debounced input value
int ButtonVal;
   // If we have gone on to the next millisecond
  if (millis() != time)
    // check analog pin for the button value and save it to ButtonVal
    ButtonVal = analogRead(analogpin);
    if(ButtonVal == current_state && counter >0)
      counter--;
    if(ButtonVal != current_state)
      counter++;
    // If ButtonVal has shown the same value for long enough let's switch it
    if (counter >= debounce_count)
      counter = 0;
      current_state = ButtonVal;
      //Checks which button or button combo has been pressed
      if (ButtonVal > 0)
        ButtonCheck();
    time = millis();
void ButtonCheck()
  // loop for scanning the button array.
  for(int i = 0; i <= 21; i++)
    // checks the ButtonVal against the high and low vales in the array
    if(ButtonVal >= Button[i][j] && ButtonVal <= Button[i][j+1])
      // stores the button number to a variable
      label = Button[i][0];
      Action();
void Action()
  if(label == 1)
    Serial.println("Up Button");
  if(label == 2)
    Serial.println("Down Button");
  if(label == 3)
    Serial.println("Left Button");
  if(label == 4)
    Serial.println("Right Button");
  if(label == 5)
    Serial.println("Action Button #1");
  if(label == 6)
    Serial.println("Action Button #2");
  if(label == 8)
    Serial.println("Left and Up Buttons");
  if(label == 9)
    Serial.println("Right and Up Buttons");
  if(label == 12)
    Serial.println("Left and Down Buttons");
  if(label == 13)
    Serial.println("Right and Down Buttons");
  if(label == 21)
    Serial.println("Action Buttons #1 and #2");
  //Serial.println("Button =:");
  //Serial.println(label);
  //delay(200);
Next i will be working on a nice 12 button keypad using this method. Sure you can get a 12 button keypad now but you'll be using row and column scanning to detect the buttons which takes up 7 digital I/O pins. With this analog button method i can have a 12 button keypad that only needs +5, Ground and a single analog pin. And this keypad will be able to accept button combinations. Hard part will be working out the best resistor values for it, the possible button combos and analog values. Not that a keypad would have much use for combos but it will be there. Besides the pad could always be used as a directional pad too.
Easy as a falling apple!
When somebody tells me how something works or can be done, I try to remember how big the universum is compared to me...
Good work. I will use your idea in a later project.
I had such a setup as well. Some of the LCD shields do this. The issue is: it is not really 100%, especially if your voltage varies or your resistors vary (e.g. due to temperature changes). Last summer it started to fail during some very hot days.
--> I would stick to read the pins digitally. If necessary using a shift register.
Cheers, Udo
Thanks for this :). I'll be using buttons on my rgb lamp whenever all parts come in.
Very true. Power supply instability and temperature changes can effect the readings. This is why i tried to get resistor values so that the received value on the analog pins had a good separation to them. Then you won't get any button overlaps do to the possible instability. So i suggest when using this to verify the resistor readings before implementing this. Fortunately if your using USB power from your PC its going to be pretty stable. Room temp is a different story.
But if the resistor values have a good separation then you should be able to adjust the high and love values for the buttons to compensate for any variation.
Made some changes to the code and incorporated an LCD. Basically the code now moves the cursor around the LCD screen. Now with the LCD connected the code worked fine. Then when i turned on the back light it became such a drain on the power that the buttons didn't work. So i went and changed the values to compensate for this.
I also did testing using a battery pack of 4 AAA batteries and a 9V battery. It all works perfectly well. Though the batteries are relatively new.
Now the values for button 1 + button 5 and button 1 + button 6 overlap. But thats not a problem in this configuration. We are only using buttons 1, 2, 3, 4, 5, 6, 1+3, 1+4, 2+3, and 2+4. Buttons 5 and 6 havn't been assigned to do anything yet.
AnalogButton_Combos
Version 0.1
The Circuit:
         Analog pin 5
            |--------|--------|-------|-------|-- +5V
For this code you want to arrange the buttons in a d pad
cofiguration and 2 action buttons. btn1 up, btn 2 down,
btn3 left, btn4 right, btn 6 A, btn 7 B.
February 24, 2010
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int Button[21][3] = {{1, 834, 838}, // button 1  *up
                     {2, 734, 738}, // button 2  *down
                     {3, 604, 611}, // button 3  *left
                     {4, 314, 319}, // button 4  *right
                     {5, 174, 179}, // button 5  *A
                     {6, 87, 92}, // button 6    *B
                     {7, 892, 897}, // button 1 + button 2
                     {8, 870, 878}, // button 1 + button 3
                     {9, 847, 852}, // button 1 + button 4
                     {10, 840, 845}, // button 1 + button 5
                     {11, 836, 841}, // button 1 + button 6
                     {12, 815, 822}, // button 2 + button 3
                     {13, 765, 770}, // button 2 + button 4
                     {14, 749, 754}, // button 2 + button 5
                     {15, 741, 746}, // button 2 + button 6
                     {16, 670, 675}, // button 3 + button 4
                     {17, 639, 644}, // button 3 + button 5
                     {18, 623, 627}, // button 3 + button 6
                     {19, 404, 409}, // button 4 + button 5
                     {20, 359, 364}, // button 4 + button 6
                     {21, 239, 243}}; // button 5 + button 6
int ButtonVal;
int x = 0;
int y = 0;
  lcd.begin(16, 2);
  lcd.setCursor(x,y);
  lcd.write(255);
      counter--;
      counter++;
      counter = 0;
      if (ButtonVal > 0)
        ButtonCheck();
    time = millis();
void ButtonCheck()
      Action();
void Action()
  // mover cursor up
  if(label == 1 && y > 0)
    y = y - 1;
  // move cursor down
  if(label == 2 && y < 1)
    y = y + 1;
  // move cursor left
  if(label == 3 && x > 0)
    x = x - 1;
  // move cursor right
  if(label == 4 && x < 15)
    x = x + 1;
  if(label == 5)
    // action button A
  if(label == 6)
    // action button B
  // move cursor left and up
  if(label == 8 && x > 0 && y > 0)
    x = x - 1;
    y = y - 1;
  // move cursor right and up
  if(label == 9 && x < 15 && y > 0)
    x = x + 1;
    y = y - 1;
  // move cursor left and down
  if(label == 12 && x > 0 && y < 1)
    x = x - 1;
    y = y + 1;
  // move cursor right and down
  if(label == 13 && x < 15 && y < 1)
    x = x + 1;
    y = y + 1;
  if(label == 21)
    // action button A + Bk
    lcd.clear();
    lcd.setCursor(x, y);
    lcd.write(255);
thank you so much for the diagram, I saw another wiring diagram to accomplish something similar but it was much more difficult to read, this was perfect and got multiple buttons on one analog pin going for me in minutes, thank you!
To unambiguously decode multiple, simultaneous buttons, binary weighting for the button values seems like the way to go. This can be done by connecting the buttons to an R-2R ladder network. There is a good article on this at Resistor ladder - Wikipedia.
If all resistors and the reference were perfect, best possible resolution would be 10 buttons - one for each bit of ADC converter accuracy. In practice, 8 buttons may be readable in any combination if the ladder is constructed from 0.1% precision resistors.
Don't mind the nominal precision. Just buy a charge of any equal resistors.... They will be equal...
(I think this concept has been discussed three times during the last month :slight_smile: )
Hi all
You may be interested in the following pages:
multiple buttons in an analog input
Multiple buttons on a digital input
(The pages are in Spanish, but have plenty of pictures and have a machine translator in the top right of the page)
Great tutorial! Thanks for share it with us.
I would like to apply this idea but only for 4 buttons. I suppose that you made multiple experiments, so may be you could propose to me what resistances to use. Any idea or proposal?
Thanks!
I have something similar to this hooked up in my car, the OEM steering wheel controls are 8 buttons with different resistance values associate with each, all going through the clockspring on 1 wire. However, like stated above, the voltage variance make some of them hard to distinguish depending on what accessories are running in my car. What I did was take the null button resistance value, and I scale my readings to that continuously, so any fluctuations are accounted for.
Thanks!
I tried the faster option... to try the same circuit except the last button and the last resistance to have 4 buttons configuration. And it runs!!!
FYI, here are the values (minimum and maximum) from reading the analog pin, when using different buttons and combinations:
button min. max.
1 839 840
2 736 738
3 608 609
4 316 317
1 2 897 899
1 2 3 916 918
1 2 3 4 921 923
1 2 4 903 905
1 3 877 879
1 3 4 886 888
1 4 853 854
2 3 820 821
2 3 4 837 838
2 4 768 770
3 4 672 674
Just only to combinations results dangerously near:
button 1 and buttons 2+3+4
But if you don´t use this combination in you program setting, it should not be a problem.
I hope it could be useful for your projects.
Cheers,
