Hi all,
Currently having a bit of an issue bringing some code together. I have two separate devices if you will, that I want to run on the same arduino. The first is an oled screen that displays a message which changes to a bitmap qr code for a few seconds after button is pressed:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(128, 64, &Wire);
const unsigned char myBitmap [] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x77, 0x61, 0x98, 0x3e, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x36, 0x61, 0x98, 0x1c, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x38, 0x01, 0xe1, 0xec, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x30, 0x7f, 0xe7, 0x9c, 0xc0, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x30, 0x7f, 0xe7, 0xbc, 0xc0, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x30, 0x66, 0x78, 0x7c, 0xc0, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x37, 0x86, 0x18, 0x04, 0xc0, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x3e, 0x19, 0xe7, 0x84, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xfe, 0x3e, 0x19, 0xe7, 0x84, 0x7f, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x36, 0x66, 0x66, 0x64, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x76, 0x66, 0x46, 0xe6, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x67, 0x81, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x23, 0x81, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x0f, 0x36, 0x01, 0x81, 0xf3, 0xc0, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0x1f, 0xf6, 0x20, 0x07, 0xb0, 0xc1, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0x3f, 0xf6, 0x60, 0x07, 0x90, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0xf0, 0x70, 0x00, 0xc3, 0xf0, 0x30, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0xf0, 0x30, 0x01, 0xe1, 0xf0, 0x30, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf8, 0x0f, 0xf8, 0x3f, 0xff, 0xe7, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x0f, 0xf8, 0x7f, 0xff, 0xe7, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0x03, 0x00, 0x66, 0x78, 0xf3, 0xb3, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0x03, 0x00, 0x66, 0x78, 0x73, 0x33, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0xf3, 0x8f, 0x86, 0x60, 0x30, 0x30, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0xf3, 0xcf, 0x86, 0x60, 0x10, 0x30, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xcf, 0x06, 0x19, 0xe7, 0x84, 0xf3, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xcf, 0x02, 0x19, 0xe7, 0x84, 0xf3, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xcc, 0xc1, 0x9e, 0x07, 0x90, 0xcf, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x3c, 0x37, 0xe6, 0x18, 0x07, 0x0f, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x3c, 0x77, 0xe6, 0x18, 0x07, 0x8f, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xfe, 0x7e, 0x79, 0x83, 0xf3, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xf0, 0x0e, 0x78, 0x00, 0x73, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfb, 0xe0, 0x0e, 0x38, 0x00, 0x73, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0xc6, 0x18, 0x18, 0x63, 0xc0, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0xc2, 0x18, 0x38, 0x61, 0xc0, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfc, 0xfc, 0x31, 0xf8, 0x7e, 0x60, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x71, 0xfc, 0xf8, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xff, 0xf9, 0xe7, 0xc3, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x79, 0xff, 0xe7, 0x86, 0xc7, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x39, 0xfe, 0x67, 0x84, 0xcf, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xfe, 0x3e, 0x00, 0x67, 0x87, 0xcf, 0xdf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x3e, 0x00, 0x67, 0x87, 0xcf, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x3e, 0x0f, 0xe0, 0x40, 0x0c, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x3e, 0x1f, 0xe0, 0x60, 0x0c, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x37, 0x99, 0x98, 0x67, 0x0c, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0x03, 0x30, 0x66, 0x60, 0x13, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x33, 0xe1, 0xfe, 0x63, 0xc3, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x33, 0xe1, 0xfe, 0x61, 0xc3, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x31, 0x9f, 0xe7, 0xe0, 0xcf, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x71, 0x9f, 0xe7, 0xe0, 0xcf, 0x3f, 0xff, 0xff, 0xff, 0xff,
const int buttonPin = 6;
int pushCounter = 0;
int buttonState = 0 ;
pinMode(buttonPin, INPUT);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.clearDisplay();
delay(2000);
buttonState = digitalRead(buttonPin);
Serial.println(buttonState);
if (buttonState == HIGH) {
pushCounter++;
if (pushCounter == 1) {
display.drawBitmap(0, 0, myBitmap, 128, 64, WHITE);
display.display();
delay(10000);
pushCounter = 0;
}`Preformatted text`
if (pushCounter == 0) {
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(30, 5);
display.println("Welcome to");
display.setTextSize(2);
display.setCursor(15, 20);
display.println("Mi Waste");
display.setCursor(10, 50);
display.println("recycling rewards");
display.display();
The second is a digital scale which uses load cells to measure a weight, the values of which are output to an LCD screen:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
#define DT 4
#define SCK 5
#define sw 2
long sample = 0;
float val = 0;
long count = 0;
unsigned long readCount(void)
unsigned long Count;
unsigned char i;
pinMode(DT, OUTPUT);
digitalWrite(DT, HIGH);
digitalWrite(SCK, LOW);
Count = 0;
pinMode(DT, INPUT);
while (digitalRead(DT));
for (i = 0; i < 24; i++)
digitalWrite(SCK, HIGH);
Count = Count << 1;
if (digitalRead(DT))
Count++;
Count = Count ^ 0x800000;
return (Count);
pinMode(SCK, OUTPUT);
pinMode(sw, INPUT_PULLUP);
lcd.begin(16, 2);
lcd.print(" Weight ");
lcd.setCursor(0, 1);
lcd.print(" Measurement ");
lcd.clear();
calibrate();
count = readCount();
int w = (((count - sample) / val) - 2 * ((count - sample) / val));
Serial.print("weight:");
Serial.print((int)w);
Serial.println("g");
lcd.setCursor(0, 0);
lcd.print("Weight ");
lcd.print(w);
lcd.print("g ");
if (digitalRead(sw) == 0)
val = 0;
sample = 0;
w = 0;
count = 0;
calibrate();
void calibrate()
lcd.clear();
lcd.print("Calibrating...");
lcd.print("Please Wait...");
for (int i = 0; i < 100; i++)
sample += count;
Serial.println(count);
sample /= 100;
Serial.print("Avg:");
Serial.println(sample);
lcd.clear();
lcd.print("Put 100g & wait");
count = 0;
while (count < 1000)
count = sample - count;
lcd.clear();
lcd.print("Please Wait....");
delay(2000);
val += sample - count;
Serial.println(sample - count);
val = val / 100.0;
val = val / 100.0; // put here your calibrating weight
lcd.clear();
Both sets of code work perfectly on their own, however in my attempts to merge them, I have been unable to change the oled screen after the button press:
#define DT 4
#define SCK 5
#define sw 2
#include <SPI.h>
#include <Wire.h>
long sample = 0;
float val = 0;
long count = 0;
unsigned char i;
Count = 0;
pinMode(DT, INPUT);
Count = Count << 1;
Count++;
return (Count);
for (;;);
delay(2000);
lcd.begin(16, 2);
lcd.clear();
calibrate();
lcd.print(w);
lcd.print("g ");
val = 0;
sample = 0;
w = 0;
count = 0;
calibrate();
void calibrate()
lcd.clear();
sample += count;
sample /= 100;
lcd.clear();
count = 0;
lcd.clear();
delay(2000);
val = val / 100.0;
lcd.clear();
pushCounter++;
display.display();
delay(10000);
pushCounter = 0;
display.display();
My thinking was that due to the arduino reading the values of the load cells via a digital input, it can't also read the button state at the same time, i.e you can't read two separate digital inputs at once. Would this be correct? If not im hoping this may just be a formatting error.
Would really appreciate any help or advice you can give,
ThanksPreformatted text
