Paul__B:
The address pins are tied to VCC - thus the $3F address. The VCC line runs through them but could be modified with some difficulty! (Data)
The +5v routing on that backpack really sucks!
Given that layout I see two ways that aren't so bad:
carefully desolder pin 1 and lift the pin and then solder a small wire on it ground.
This is a bit dangerous since if the pin bends back down you have VCC to ground short. -
two cuts, one/two jumps
- cut the trace from the pot to pin 3 of the PCF8574
- cut the trace between pins 1 and 2 of the PCF8574
(verify this with an ohm meter to ensure the trace is fully cut as it is difficult to get between the pins)
It appears that the VCC header might get power from the back side VCC plane. But if not
Solder a wire from VCC to the 2 pin header to restore VCC
scrape the solder mask just beyond pins 2 and 3 to expose the ground plane
put a tiny solder blob from pins 2 and 3 to the ground plane.
Big takeaway from this, is to carefully look at the product before buying.
I always check the product photos and make sure that what I'm getting matches the photo, and then that it is/does what I need. For i2c backpacks, I better be able to set the contrast and change the address so I have to see the address jumpers and pot on the side of the board that will be facing up when soldered to the LCD.
--- bill
