Multiple libraries were found for "Wire.h"
I'm trying to make a DIY Send It level and when I tried to verify my code I got this error message:
  Used: C:\Users\user\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.15\libraries\Wire
  Not used: C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.7\libraries\Wire
exit status 1
This is the code I tried to verify:
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
const int led0 = 1; // LED for 0° ± 0.5°
const int led1 = 3; // LED for > 0.5°
const int led2 = 4; // LED for < -0.5°
  Wire.begin();
  mpu.initialize();
  pinMode(led0, OUTPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  int16_t ax, ay, az;
  int16_t gx, gy, gz;
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  float yAngle = atan2(ay, az) * 180 / PI;
  if (yAngle >= -0.5 && yAngle <= 0.5) {
    digitalWrite(led0, HIGH);
    digitalWrite(led1, LOW);
    digitalWrite(led2, LOW);
  } else if (yAngle > 0.5) {
    digitalWrite(led0, LOW);
    digitalWrite(led1, HIGH);
  } else if (yAngle < -0.5) {
    digitalWrite(led2, HIGH);
  delay(100);
I'm using an adafruit trinket 5v and a HW-123 MPU6050 chip
What board did you select to compile for?
Please post the full error message
That is totally normal. There are many variations of the common libraries. Did you notice one is for an Adafruit board and the other is standard AVR (UNO, etc)
Finding and dealing with multiple libraries with the same name is totally normal but not
For sure, but in post 3, you asked for the full message.
Adafruit trinket (ATtiny85 @ 8MHz)
Do you mean that this last line is not normal?
Yes I saw that but I haven't found any solution online that could help me upload the code
You have not yet responded to post 2 and 3. Post the verbose verify log in code tags.
If memory serves, "Multiple libraries were found for..." is a warning rather than an error. I have to admit that I'm puzzled by the IDE looking in 2 cores though. Anyhow, let's see a verbose compiler output. ALL of it, please, not selected snippets that you think are relevant.
Is it all this you mean?
do { if (DB_ACTIVE) Serial.print(__VA_ARGS__); } while (0)
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:397:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(F("Z gyro offset = "));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:110:33: note: suggested alternative: 'Stream'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:114:33: error: 'Serial' was not declared in this scope
             do { if (DB_ACTIVE) Serial.println(__VA_ARGS__); } while (0)
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:398:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(zgOffset);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:114:33: note: suggested alternative: 'Stream'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:402:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(F("Enabling interrupt latch, clear on any read, AUX bypass enabled"));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:409:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(F("Setting magnetometer mode to power-down..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:413:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(F("Setting magnetometer mode to fuse access..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:417:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(F("Reading mag magnetometer factory calibration..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:110:33: error: 'Serial' was not declared in this scope
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:427:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(F("Adjustment X/Y/Z = "));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:428:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(asax);
     DEBUG_PRINT(asax);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:429:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(F(" / "));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:430:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(asay);
     DEBUG_PRINT(asay);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:431:5: note: in expansion of macro 'DEBUG_PRINT'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:432:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(asaz);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:434:5: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:439:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(F("Writing DMP code to MPU memory banks ("));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:440:5: note: in expansion of macro 'DEBUG_PRINT'
     DEBUG_PRINT(MPU6050_DMP_CODE_SIZE);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:441:5: note: in expansion of macro 'DEBUG_PRINTLN'
     DEBUG_PRINTLN(F(" bytes)"));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:443:9: note: in expansion of macro 'DEBUG_PRINTLN'
         DEBUG_PRINTLN(F("Success! DMP code written and verified."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:445:9: note: in expansion of macro 'DEBUG_PRINTLN'
         DEBUG_PRINTLN(F("Configuring DMP and related settings..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:448:9: note: in expansion of macro 'DEBUG_PRINT'
         DEBUG_PRINT(F("Writing DMP configuration to MPU memory banks ("));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:449:9: note: in expansion of macro 'DEBUG_PRINT'
         DEBUG_PRINT(MPU6050_DMP_CONFIG_SIZE);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:450:9: note: in expansion of macro 'DEBUG_PRINTLN'
         DEBUG_PRINTLN(F(" bytes in config def)"));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:452:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Success! DMP configuration written and verified."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:454:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting DMP and FIFO_OFLOW interrupts enabled..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:457:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting sample rate to 200Hz..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:460:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting clock source to Z Gyro..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:463:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting DLPF bandwidth to 42Hz..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:466:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting external frame sync to TEMP_OUT_L[0]..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:469:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting gyro sensitivity to +/- 2000 deg/sec..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:472:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting DMP configuration bytes (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:476:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Clearing OTP Bank flag..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:479:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting X/Y/Z gyro offsets to previous values..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:489:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 1/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:495:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 2/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:499:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Resetting FIFO..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:502:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Reading FIFO count..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:505:13: note: in expansion of macro 'DEBUG_PRINT'
             DEBUG_PRINT(F("Current FIFO count="));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:506:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(fifoCount);
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:510:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 3/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:514:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 4/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:518:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Disabling all standby flags..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:521:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting accelerometer sensitivity to +/- 2g..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:524:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting motion detection threshold to 2..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:527:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting zero-motion detection threshold to 156..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:530:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting motion detection duration to 80..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:533:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting zero-motion detection duration to 0..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:536:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting AK8975 to single measurement mode..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:541:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting up AK8975 read slave 0..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:547:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting up AK8975 write slave 2..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:554:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting up slave access delay..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:559:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Enabling default interrupt behavior/no bypass..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:563:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Enabling I2C master mode..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:565:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:567:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Rewriting I2C master mode enabled because...I don't know"));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:569:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Enabling and resetting DMP/FIFO..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:572:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 5/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:575:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 6/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:578:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 7/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:581:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 8/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:584:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 9/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:587:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 10/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:590:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 11/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:594:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Reading final memory update 12/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:606:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 13/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:609:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 14/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:612:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 15/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:615:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 16/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:618:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 17/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:622:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Waiting for FIRO count >= 46..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:624:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Reading FIFO..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:626:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Reading interrupt status..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:629:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 18/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:633:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Waiting for FIRO count >= 48..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:635:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:637:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:639:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:641:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:643:13: note: in expansion of macro 'DEBUG_PRINTLN'
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:646:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Writing final memory update 19/19 (function unknown)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:650:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Disabling DMP (you turn it on later)..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:653:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Setting up internal 48-byte (default) DMP packet buffer..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:659:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("Resetting FIFO and clearing INT status one last time..."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:663:13: note: in expansion of macro 'DEBUG_PRINTLN'
             DEBUG_PRINTLN(F("ERROR! DMP configuration verification failed."));
c:\Users\Ludvig\Documents\Arduino\libraries\MPU6050\src\MPU6050_9Axis_MotionApps41.cpp:667:9: note: in expansion of macro 'DEBUG_PRINTLN'
         DEBUG_PRINTLN(F("ERROR! DMP code verification failed."));
  Used: C:\Users\Ludvig\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.15\libraries\Wire
  Not used: C:\Users\Ludvig\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.7\libraries\Wire
exit status 1
Compilation error: exit status 1
Please post a photo of the front and back of the board, and a screen grab of the selected board.
The library.properties says the MPU6050 library is for the following board architectures. I changed the board to UNO and it compiles fine.
architectures=avr,samd,sam,esp8266,esp32,stm32,renesas,renesas_portenta,renesas_uno
If I can be direct, if you don't know the difference between an exit status and an error or how to validate that a library is compatible with your board, maybe you need to start at the beginning and learn how to use all the tools.
Exactly.
Notice the occurrence of the word 'error' in this line, and in many others that follow.
Those are your errors. Not the note at the end that the IDE found multiple libraries and chose the proper one.
Bottom line: the Adafruit Trinket 5V doesn't have a Serial object, it seems, and your MPU6050 is trying to send debugging info to it. The MPU6050 library isn't compatible with an ATtiny85 based board as is.
See the difference showing all the information makes?
Maybe I should start with something simpler...
