Hi Guys
I am really new to programming but I can see that the Arduino can make few of my ideas come to life.
I have played around with programming some led strips and got that right but for only 1 program.
Question...... Can I run more than 1 program. The project I am currently working requires 1 set of LEDS to be Red and then flash when a button is activated, at the same time I need a few LEDs to be on a static colour and when the same button is pressed the LEDs start to run a rainbow sequence and then lastly a sound byte needs to play out when the same button is pressed.
Your help would be greatly appreciated in learning how to make this possible.
Ok, so I think I could make that work for my project.
So as I understand it then I can write code to flash lights and play the sound byte all in the same code, effectively giving me the result I am looking for.
Yes, provided you program the sketch appropriately.
Avoid delay() and other Arduino functions that will stall the CPU. You can read about good code style:
