Multiple RFID readers (RC522) with Arduino
Hi guys,
I hope that you'll be able to help me.
I made two differents prototypes using one arduino Uno. One with one RFID reader, one with three different RFID readers. They are both working fine.
So I want now to move forward on a new prototype, with 9 differents RFID readers (type RC522) on a arduino mega, I've updated my script (based on GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522).
But I've got the issue for every readers :
Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
This is my code.
 * Example sketch/program showing how to read data from more than one PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
 * MFRC522 based RFID Reader on the Arduino SPI interface.
 * Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
 *          and knowledge are required!
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         5          // Configurable, see typical pin layout above
#define SS_1_PIN        30        // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
#define SS_2_PIN        32          // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define SS_3_PIN        34
#define SS_4_PIN        36
#define SS_5_PIN        38
#define SS_6_PIN        40
#define SS_7_PIN        42
#define SS_8_PIN        44
#define SS_9_PIN        46
#define NR_OF_READERS   9
byte ssPins[] = {SS_1_PIN, SS_2_PIN, SS_3_PIN,SS_4_PIN, SS_5_PIN, SS_6_PIN,SS_7_PIN, SS_8_PIN, SS_9_PIN};
MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
 * Initialize.
  Serial.begin(9600); // Initialize serial communications with the PC
  while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();        // Init SPI bus
  for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
    mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
    //Serial.print(F("Lecteur "));
    //Serial.print(reader);
    //Serial.print(F(": "));
    mfrc522[reader].PCD_DumpVersionToSerial();
 * Main loop.
    // Look for new cards
    if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
      Serial.print(F(";"));
      // Show some details of the PICC (that is: the tag/card)
      //Serial.print(F(": ID de la carte:"));
      dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
      //Serial.print(F("Type PICC: "));
      //MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
      //Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
      // Halt PICC
      mfrc522[reader].PICC_HaltA();
      // Stop encryption on PCD
      mfrc522[reader].PCD_StopCrypto1();
    } //if (mfrc522[reader].PICC_IsNewC
  } //for(uint8_t reader
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    //Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i] < 0x10 ? "0" : "");
    Serial.print(buffer[i], HEX);
It seems to be pretty basic stuff but I can't figure out how to make it work.
Someone have any advices?
You reset every board each time you initialize the next. This way the initialization is gone as soon as the next board is initialized. Define the RST_PIN to 255 (disables the hardware reset) and you might have better results.
