error Multiple RFID
Hi every one,
I'm newbie, i saw video tutorial read multiple RFID at the same time https://www.youtube.com/watch?v=HmGmFknAIqc and https://www.youtube.com/watch?v=ahc8Yai_sWI
but it
Reader 0: Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Reader 1: Firmware Version: 0x0 = (unknown)
if i connect first RFID without VCC 3.3V then second RFID can read and connect second RFID without VCC 3.3V then first RFID can read.
no way! :roll_eyes: :'( :'(
Can you help me?
(deleted)
Hi spycatcher2k
i use example code in library
 * Example sketch/program showing how to read data from more than one PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
 * MFRC522 based RFID Reader on the Arduino SPI interface.
 * Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
 *          and knowledge are required!
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_PIN = 9;     // Configurable, see typical pin layout above
constexpr uint8_t SS_1_PIN = 10;   // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
constexpr uint8_t SS_2_PIN = 8;    // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
constexpr uint8_t NR_OF_READERS = 2;
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
 * Initialize.
  Serial.begin(9600); // Initialize serial communications with the PC
  while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();        // Init SPI bus
  for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
    mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
    Serial.print(F("Reader "));
    Serial.print(reader);
    Serial.print(F(": "));
    mfrc522[reader].PCD_DumpVersionToSerial();
 * Main loop.
    // Look for new cards
    if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
      // Show some details of the PICC (that is: the tag/card)
      Serial.print(F(": Card UID:"));
      dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
      Serial.print(F("PICC type: "));
      MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
      Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
      // Halt PICC
      mfrc522[reader].PICC_HaltA();
      // Stop encryption on PCD
      mfrc522[reader].PCD_StopCrypto1();
    } //if (mfrc522[reader].PICC_IsNewC
  } //for(uint8_t reader
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
