Finally I can send from Simulink/Matlab to arduino, the problem I am getting is that Sent data is not updated, I mean if I start simulation It starts displaying the sent value & If I try to update it (change the sent data value) it doesn't update.
My second problem is that I want to send multiple data (a vector of data), how would I receive them in arduino?
Here is MAtlab code
Here is arduino code :
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x3F for a 16 chars and 2 line display
int foundValue = 0;
int cursor = 0;
int Save[3];
lcd.init();
lcd.clear();
lcd.backlight(); // Make sure backlight is on
if (Serial.available() > 0) {
uint32_t rc;
for(int i=0; i<4;i++)
rc = Serial.read();
Save[i]=rc;
int Sum = Save[0]+Save[1]*256;
lcd.setCursor(0,0);
lcd.print(Sum);
delay(1000); //Wait for 1s
The problem here is you receive one byte on the serial, and then assume you have received 4. Why not wait until you have received 4 bytes and then do your loop?
Paul
Sorry but I did no get what do you mean by you do not own & anything can happen with when this is done...
Actually, I created save to convert from 8 bits that serial can handle to 16 bits so I can get my >255 values... I don't know if you got what I say...
yes I think I did, it displays the right value, but still cannot be updated in real time, here is the code :
int foundValue = 0;
int cursor = 0;
byte Save[4];
lcd.init();
lcd.clear();
uint32_t rc;
Save[i]=Serial.read();
lcd.setCursor(0,0);
lcd.print(Sum);
Nope! Still are processing 4 bytes in the buffer when only 1 has arrived from your PC.
While you are at it, consider if you are REVERSING the order of the bytes sent from the PC.
Paul
int Save[3]; //three element array Save
Save[3]=rc; //
Your code will corrupt memory. If you have 3 elements in an array, they have index numbers: 0, 1, 2. You are trying to write data to index number 3. The compiler may have placed something else in the memory location you are writing, and the consequences are undefined, i.e. anything can happen.
EDIT: I see you have redefined the size of Save correctly to hold 4 values.
I am sending an uint_32t value (with 4 bytes), Actually the sent data value is 400 which is more than 255 it means that it occupies at least 2 bytes, I think that 2 bytes has arrived from my pc, am I wrong? Correct me if I am wrong please!
Ok, you are getting close. When your code discovers there is one or more unread byte in the buffer, what does it do? It reads 4 bytes. One is real, the other three are imaginary.
Paul
