Multiple Xbee and Mutliple Arduino
Guys, we need some help regarding arduinos and multiple xbees.
We are working on a thesis on Monitoring Flood using 6 xbees(with one coordinator node and 5 sensor nodes using ultrasonic sensors). Each of these nodes are connected to an arduino. We want to be able to communicate each of the sensor nodes their data to be able to transfer to the coordinator node. This is my first time using xbees and we dont really know where to start. We need help as we are already close to our thesis defense and we havent figured out anything yet.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
do a web search for arduino xbee mesh you will get plenty of links
what ultrasonic sensors are you using?
Hello thank you for the reply, I am currently searching for arduino xbee mesh as you said. True enough, there are lot of links pertaining to the subject. I am currently understanding more about xbees and how they work.
I am using the HC SR04 ultarsonic sensors to measure the water level.
how far apart are the devices?
I used Lora communications in a similar project using a waterproof JSN-SR04T Ultrasonic Distance Sensor and ds18b20-digital-temperature-sensor
some results
unfortunatly not used XBEE for many years and then it was on a PIC24 microcontroller
what XBEE modules are you using?
Unfortunately we have already proposed Using Xbee for our project. It would be hard to change from xbee to lora at this time. Thanks for the insight tho.
We are using Two Xbee S2C Pro and Four Xbee S2C.
XBee is a good choice as it supports long distance communication similar to Lora
looking for my XBee - still looking!
Thank you horace. Any help is much appreciated
may be worth asking on the XBee forum for assistance
