Hello,
I wanted to make a program which use webserver to control relay (easy) but send json url when a contact state change.
I've made this (from internet inspiration ) :
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = { 192, 168, 77, 107 }; // ip in lan assigned to arduino
byte gateway[] = { 192, 168, 77, 254 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port arduino server will use
EthernetClient client;
//char serverName[] = "web.comporium.net"; // (DNS) zoomkat's test web page server
byte serverName[] = { 192, 168, 77, 100 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
pinMode(4, OUTPUT); //pin 5 selected to control
pinMode(5, OUTPUT);
pinMode(2, INPUT_PULLUP);
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println("server/client 1.0 test 7/03/12"); // keep track of what is loaded
Serial.println("Send an g in serial monitor to test client"); // what to do to test client
attachInterrupt(digitalPinToInterrupt(2),sendChange, CHANGE);
void loop(){
// check for serial input
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
else {
client.println("HTTP/1.1 200 OK"); //send new page on browser request
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
client.println("<a href='/?1on' target='inlineframe'>ON</a>");
client.println("<a href='/?1off' target='inlineframe'>OFF</a>");
client.println("<a href='/?2on' target='inlineframe'>2ON</a>");
client.println("<a href='/?2off' target='inlineframe'>2OFF</a>");
client.println("<IFRAME name=inlineframe style='display:none'>");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("1on") >0)//checks for on
digitalWrite(4, HIGH); // set pin 5 high
Serial.println("Led On");
if(readString.indexOf("1off") >0)//checks for off
digitalWrite(4, LOW); // set pin 5 low
Serial.println("Led Off");
if(readString.indexOf("2on") >0)//checks for on
digitalWrite(5, HIGH); // set pin 5 high
if(readString.indexOf("2off") >0)//checks for off
digitalWrite(5, LOW); // set pin 5 low
//clearing string for next read
readString="";
void sendChange()
if (digitalRead(2) == HIGH)
if (client.connect(serverName, 8084)) {
Serial.println("connectedOn");
client.println("GET /json.htm?type=command¶m=switchlight&idx=156&switchcmd=On HTTP/1.0");
client.println();
else {
Serial.println("connection failed");
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println("disconnecting.");
Serial.println("==================");
client.stop();
Serial.println("connectedOff");
client.println("GET /json.htm?type=command¶m=switchlight&idx=156&switchcmd=Off HTTP/1.0");
client.println();
else {
Serial.print(c);
client.stop();
It works, but when I'm playing with the contact webserver stop responding.
Can anyone see want's wrong ?
