I'm having a problem using the CD74HC4067 multiplexer to read analog values from several hall sensors (A1301-2). The output seems to be very erratic -- sometimes it reads the values properly and sometimes it seems some of the values leak into some of the other outputs (ghosting? but a1301s have super low output impedance...) and sometimes different sensors get printed out of order... Have no idea what's going on?
If anybody can help me out that'd be awesome and super appreciated.
Here's my super simple code which I'm using to try to debug...
//Mux control pins
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
//Mux in "SIG" pin
int SIG_pin = A0;
void setup(){
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
void loop(){
//Loop through and read all 8 sensor values
for(int i = 0; i < 8; i++){
Serial.print(readMux(i));
Serial.print(" ");
delay(30);
Serial.println("");
int readMux(int channel){
int controlPin[] = {s0, s1, s2, s3};
int muxChannel[16][4]={
{0,0,0,0}, //channel 0
{1,0,0,0}, //channel 1
{0,1,0,0}, //channel 2
{1,1,0,0}, //channel 3
{0,0,1,0}, //channel 4
{1,0,1,0}, //channel 5
{0,1,1,0}, //channel 6
{1,1,1,0}, //channel 7
{0,0,0,1}, //channel 8
{1,0,0,1}, //channel 9
{0,1,0,1}, //channel 10
{1,1,0,1}, //channel 11
{0,0,1,1}, //channel 12
{1,0,1,1}, //channel 13
{0,1,1,1}, //channel 14
{1,1,1,1} //channel 15
//loop through the 4 sig
for(int i = 0; i < 4; i ++){
digitalWrite(controlPin[i], muxChannel[channel][i]);
//read the value at the SIG pin
int val = analogRead(SIG_pin);
//I read doing 2 analogReads back to back can sometimes help but not doing it...
//val = analogRead(SIG_pin);
//return the value
return val;
