I have got 2 IrDA En/Decoders that I need to connect to Arduino(lilypad).
IrDA <---> En/Decoder <--------v
IrDA <---> En/Decoder <---> Lilypad
The problem is Lilypad only has 1 UART port(Rx/Tx). What's the easiest way to use connect 2 IrDA? It's okay if I can only recv/send data from one at a time.
Being slow digital data, you could do it with just a couple of transistors too.
Let both devices listen at the same time.
Give both an open collector transistor to drive with an 3rd to re-invert the signal to you.
