Im currently trying to make a camera slider with pan and tilt head and am using the accelstepper and multistepper library to move 3 motors to a coordinate. The code enables me to set in and out positions for all three motors and then moves the motors simultaneously to the from the in position to the out position. Currently, I am using a potentiometer to set the speed. I was wondering if there was a way for my to set a time ,e.g 10 mins or 30 seconds, to complete the movement, rather than setting a arbitrary speed.
Thanks
tomdixo:
Probably.
Please post the program that represents your best attempt and tell us in detail what it actually does and what you want it to do that is different. It will make it much easier to focus on the parts you need help with rather than wasting time on things that you can do.
Maybe all you need to do is calculate the speed that will get the motor to its destination in the desired time.
...R
Below I have inserted the code:
Currently, I can set an in point and out point whereever I want for each of he motors, therefore the distance each time will not be constant meaning I will not be able to just calculate the time for each speed like you suggested.
What I want to be able to do is set the in and out points then choose how long I want it to take to go from the in point to the out point.
Also, this isn't my code, I have adjusted the code of the creator who is commented in.
/*DIY Camera Slider with Pan and Tilt Head
by Dejan Nedelkovski
www.HowToMechatronics.com
Library - AccelStepper by Mike McCauley:
http://www.airspayce.com/mikem/arduino/AccelStepper/index.html
#include <AccelStepper.h>
#include <MultiStepper.h>
#define JoyX A0 // Joystick X pin
#define JoyY A1 // Joystick Y pin
#define slider A2 // Slider potentiometer
#define inOutPot A3 // In and Out speed potentiometer
#define JoySwitch 10 // Joystick switch connected
#define InOutSet 12 // Set Button
#define limitSwitch 11
#define inLED 8
#define outLED 9
// Define the stepper motors and the pins the will use
AccelStepper stepper1(1, 7, 6); // (Type:driver, STEP, DIR)
AccelStepper stepper2(1, 5, 4);
AccelStepper stepper3(1, 3, 2);
MultiStepper StepperControl; // Create instance of MultiStepper
long gotoposition[3]; // An array to store the In or Out position for each stepper motor
int JoyXPos = 0;
int JoyYPos = 0;
int sliderPos = 0;
int currentSpeed = 100;
int inOutSpeed = 100;
int XInPoint = 0;
int YInPoint = 0;
int ZInPoint = 0;
int XOutPoint = 0;
int YOutPoint = 0;
int ZOutPoint = 0;
int InandOut = 0;
// Set initial seed values for the steppers
stepper1.setMaxSpeed(6000);
stepper1.setSpeed(200);
stepper2.setMaxSpeed(3000);
stepper2.setSpeed(200);
stepper3.setMaxSpeed(3000);
stepper3.setSpeed(200);
pinMode(JoySwitch, INPUT_PULLUP);
pinMode(InOutSet, INPUT_PULLUP);
pinMode(limitSwitch, INPUT_PULLUP);
pinMode(inLED, OUTPUT);
pinMode(outLED, OUTPUT);
// Create instances for MultiStepper - Adding the 3 steppers to the StepperControl instance for multi control
StepperControl.addStepper(stepper1);
StepperControl.addStepper(stepper2);
StepperControl.addStepper(stepper3);
// Move the slider to the initial position - homing
while (digitalRead(limitSwitch) != 0) {
stepper1.setSpeed(5000);
stepper1.runSpeed();
stepper1.setCurrentPosition(0); // When limit switch pressed set position to 0 steps
delay(100);
// Move 200 steps back from the limit switch
while (stepper1.currentPosition() != -200) {
stepper1.setSpeed(-200);
Serial.println("hELLO");
// Limiting the movement - Do nothing if limit switch pressed or distance traveled in other direction greater then 80cm
while (digitalRead(limitSwitch) == 0 || stepper1.currentPosition() < -37800) {}
// If Joystick pressed increase the Pan and Tilt speeds
// If Set button is pressed - toggle between the switch cases
if (digitalRead(InOutSet) == 0) {
// If we hold set button pressed longer then half a second, reset the in and out positions
InandOut = 4;
switch (InandOut) {
case 0: // Set IN position
InandOut = 1;
XInPoint = stepper1.currentPosition(); // Set the IN position for steppers 1
YInPoint = stepper2.currentPosition(); // Set the IN position for steppers 2
ZInPoint = stepper3.currentPosition(); // Set the IN position for steppers 3
digitalWrite(inLED, HIGH); // Light up inLed
case 1: // Set OUT position
InandOut = 2;
XOutPoint = stepper1.currentPosition(); // Set the OUT Points for both steppers
YOutPoint = stepper2.currentPosition();
ZOutPoint = stepper3.currentPosition();
digitalWrite(outLED, HIGH);
case 2: // Move to IN position / go to case 3
InandOut = 3;
inOutSpeed = analogRead(inOutPot); // Auto speed potentiometer
// Place the IN position into the Array
gotoposition[0] = XInPoint;
gotoposition[1] = YInPoint;
gotoposition[2] = ZInPoint;
stepper1.setMaxSpeed(inOutSpeed);
stepper2.setMaxSpeed(inOutSpeed);
stepper3.setMaxSpeed(inOutSpeed);
StepperControl.moveTo(gotoposition); // Calculates the required speed for all motors
StepperControl.runSpeedToPosition(); // Blocks until all steppers are in position
delay(200);
case 3: // Move to OUT position / go back to case 2
InandOut = 2;
// Place the OUT position into the Array
gotoposition[0] = XOutPoint;
gotoposition[1] = YOutPoint;
gotoposition[2] = ZOutPoint;
StepperControl.runSpeedToPosition(); // Blocks until all are in position
delay(200);
case 4: // If Set button is held longer then half a second go back to case 0
InandOut = 0;
digitalWrite(inLED, LOW);
digitalWrite(outLED, LOW);
sliderPos = analogRead(slider);
// If potentiometer is turned left, move slider left
if (sliderPos > 600) {
sliderPos = map(sliderPos, 600, 1024, 0, 6000);
stepper1.setSpeed(sliderPos); // Increase speed as turning
// If potentiometer is turned right, move slider right
else if (sliderPos < 400 ) {
sliderPos = map(sliderPos, 400, 0, 0, 6000);
stepper1.setSpeed(-sliderPos); // Increase speed as turning
// If potentiometer in middle, no movement
else {
stepper1.setSpeed(0);
// Joystick X - Pan movement
JoyXPos = analogRead(JoyX);
// if Joystick is moved left, move stepper 2 or pan to left
if (JoyXPos > 600) {
stepper3.setSpeed(500);
// if Joystick is moved right, move stepper 2 or pan to right
else if (JoyXPos < 400) {
stepper3.setSpeed(-500);
// if Joystick stays in middle, no movement
else {
stepper3.setSpeed(0);
//Joystick Y - Tilt movement
JoyYPos = analogRead(JoyY);
if (JoyYPos > 600) {
stepper2.setSpeed(500);
else if (JoyYPos < 400) {
stepper2.setSpeed(-500);
else {
stepper2.setSpeed(0);
// Execute the above commands - run the stepper motors
stepper2.runSpeed();
stepper3.runSpeed();
I think you need to work with this piece of code
Which motor will determine the total time? That will be based on the combination of the number of steps and max speed for each motor. If all the motors use the same max speed then I presume the motor that moves the most steps determines the duration.
Suppose (very simple example) the motor moves 1000 steps at max of 100 steps per second then it will need 10 seconds to do the move. If you want it to do the move in 20 seconds then reduce the max to 50 steps per second.
(But I may be all wrong
...R
Thanks for that I think you helped me figure out what to do,
I think Ill do it by taking the total steps for the sliding axis (which determines the whole length of the movement) then just divide that by how long I want it to take to get the speed.
