Muting a buzzer with a button until a value is reached again
Hi! I recently started my Arduino journey with a kit I bought online and some YouTube tutorials. This is my first project that I am attempting on my own and I got 90% of my hardware doing what it is supposed to. I am struggling with the code to get the last bit working the way I want it to. My project consists of 2 x LEDs, 1 pushbutton, 1 x buzzer, 1 x photo resistor and some 330/10K resistors (I will include a picture of my setup and code with this post). The ultimate aim of my project is to create an alarm to inform me when we have a power outage (we have regular power outages and have solar installed, but need to manage our power consumption carefully when there is a power outage). The way I want to achieve this is to read the light level of an indicator light installed on the distribution board (DB) that receives the main electrical supply. I got my project to work to the point where my generic UNO is reading the light values from a photoresistor and then turning on a green LED when it reads a value above the set threshold, or turning a red LED + the buzzer on when the light value falls below the set threshold. If I push a button, it mutes the buzzer for about 20 - 30 seconds. This is where I need help. If the buzzer goes off, I want to be able to mute the buzzer (by pushing the button) and the buzzer should stay muted until the next occasion that there is a power outage. I couldn't come up with a suitable solution to mute the buzzer as I wanted and tried a 24-hour delay in the code after the button was pushed. But as stated before, the result I am getting is a delay of +- 20-30 seconds instead of the intended 24 hours. The delay solution is also not helpful as it stops the code from continuing to read the light levels whilst the delay is still active. Could someone please assist with a solution to fix my code, or point me in the right direction? Your assistance will be greatly appreciated.
My code and a Tinkercad image of my hardware is included below.
const int photoresistorPin = A0;
const int greenLedPin = 5;
const int redLedPin = 3;
const int buzzerPin = 4;
const int switchPin = 2;
int buttonValue;
const int dt = 100;
const int dt2 = 86400000;
int lightValue;
bool buzzerEnabled = false;
  pinMode(greenLedPin, OUTPUT);
  pinMode(redLedPin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(switchPin, INPUT_PULLUP);  // Use internal pull-up resistor
  lightValue = analogRead(photoresistorPin);
  buttonValue = digitalRead(switchPin);
  Serial.println(lightValue);
  Serial.println(buttonValue);  // Print light value to serial monitor
  if (lightValue > 800) {
    // Light is bright
    digitalWrite(greenLedPin, HIGH);
    digitalWrite(redLedPin, LOW);
    noTone(buzzerPin);
  if (lightValue < 800) {
    // Light is dim
    digitalWrite(greenLedPin, LOW);
    digitalWrite(redLedPin, HIGH);
    buzzerEnabled = true;
  if (buzzerEnabled) {
    tone(buzzerPin, 4000);
  if (buzzerEnabled && buttonValue == LOW) {
    noTone(buzzerPin);
    delay(dt2);
  delay(dt);
Thanks for posting correctly with details, code tags for your first post. That's good.
You might benefit from studying state machines. Here is a small introduction to the topic: Yet another Finite State Machine introduction
your requirements should easily translate into a state diagram and then into code.
As you describe your needs, I can identify 3 states NORMAL, ACTIVATED, MUTED
NORMAL is when power is working fine
ACTIVATED is when you lost power and the alarm is sounding
MUTED is when you lost power and the alarm has been shut off.
in NORMAL mode, you go to ACTIVATED if power is lost
in ACTIVATED mode, upon button press you go to MUTED and if power comes back you go to NORMAL
in MUTED mode if power comes back you go to NORMAL
so code could look like this (typed here, mind typos) — as you can see it's easy to understand.
const byte switchPin   = 2;
const byte redLedPin   = 3;
const byte buzzerPin   = 4;
const byte greenLedPin = 5;
const byte photoresistorPin = A0;
const int photoresistorThreshold = 800;
enum : byte {NORMAL, ACTIVATED, MUTED} state = NORMAL;
bool powerIsOff()       {return analogRead(photoresistorPin) < photoresistorThreshold;}
bool powerIsOn()        {return not powerIsOff();}
bool buttonIsPressed()  {return digitalRead(switchPin) == LOW;}
void alarmOn() {
  state = ACTIVATED;
void alarmOff() {
  noTone(buzzerPin);
   state = NORMAL;
void buzzerOff() {
  noTone(buzzerPin);
  state = MUTED;
  alarmOff();
  switch (state) {
    case NORMAL:
      if (powerIsOff()) alarmOn() ;
    case ACTIVATED:
      if (powerIsOn()) alarmOff();
      else if (buttonIsPressed()) buzzerOff() ;
    case MUTED:
This will actually store 23552 in dt2. So your delay is “20-30 seconds”. Use Serial.print() to test this.
An int can only hold 16 bits, which results in a range from -32768 to 32767.
Use long instead of int.
And check out the Blink without delay example so you learn how to write a sketch that does not use delay
Yes, a state machine looks like an excellent way forward.
The key trick in a state machine is instead of trying to build the logic of the program from the right set of external inputs (buttons, and sensors and timers, etc...) and increasingly complicated if statements, you add an additional "state" variable for what the system should be doing, and use that variable to simplify the logic. At the highest level, your system sounds like it is supposed to be either ARMED, BUZZING, or MUTED (other words for @J-M-L's NORMAL, ACTIVATED and MUTED), and if you had a variable that tracked that, it would simplify the logic.
Look into state machines.
much better terms !
Thank you for your considered reply and code provided, it is much appreciated.
I will most definitely try the solution (and read up on state machines further) and revert in due course.
Please say again what software you used to make the diagram.
I'm a pen and paper type, but I do gotta say it looks nicer when it is nicer.
TIA
a7
Here's @J-M-L's sketch with a few tweaks realized (!) in simulation:
The code:
// https://wokwi.com/projects/419523916199154689
const byte powerPin = 6;
const int photoresistorThreshold = 777;
bool powerIsOff()
  bool power = analogRead(photoresistorPin) < photoresistorThreshold;
  digitalWrite(powerPin, !power);
  return power;
bool powerIsOn()
  bool power = powerIsOff();
  return !power;
void alarmOn() {
  tone(buzzerPin, 777);  // 4000 = upset cat!
  state = ACTIVATED;
void alarmOff() {
  noTone(buzzerPin);
  state = NORMAL;
void buzzerOff() {
  noTone(buzzerPin);
  state = MUTED;
  alarmOff();
  powerIsOff();  // just to set the power LED correctly at startup
  switch (state) {
    case NORMAL:
    case ACTIVATED:
    case MUTED:
There were no typos in @J-M-L's original sketch. I left the state names, I didn't think one set was better than another, and both are vaguely unsatisfactory but I have never been any good at naming things, so.
I would move the changes to the state variable into the state machine FSM switch and possibly make it a local variable. This keeps the FSM logic contained.
a7
delay() takes an unsigned long. But moving to a state machine eliminates this issue and is a better approach.
You are in good company:
There are 2 hard problems in computer science: cache invalidation, naming things, and off-by-1 errors. -- Leon Bambrick
My personal rule for naming states is to describe what the FSM is "doing", as if I were pointing at a black box and trying to describe the different things it does. I'm not defending my names, I just took words from the OP's title while I was replying.
just Keynote which is bundled free with my Mac / iPad / iPhone (a kind of powerpoint equivalent)
pen and paper will do too.
yeah - I'm always unsatisfied with the names.
ARMED sounds great, but calls for an extension of the state machine and hardware to have a way to be DISARMED
May be ALERT would be better than BUZZING since there is also the red led so it's not just buzzing ?
and then may be SILENT_ALERT after you press the button... But I don't like the long enumerators names with underscores...
I asked chatGPT for other options and got:
MONITORING , TRIGGERED , SILENCED
IDLE , ALERT , QUIET
STANDBY , ALARMING , MUTED
WATCHING , WARNING , SILENT
READY , ALERTING , SUPPRESSED
OBSERVING , ENGAGED , DEACTIVATED
probably some ideas there too.
I think I would go for MONITORING, ALERTING, SILENCED may be...
nice !
The other trick in state machines is identifying the transitions between states, and the state diagrams are excellent for that. For example, you put your finger on SILENCED and ask yourself how you want to get back to MONITORING, and then draw and arrow and label it, and later write an if-statement do the transition. In #1, @edb_sa described a time limit, so you'd perhaps need to record the time you transitioned into SILENCED, and then check whether the elapsed time is long enough to transition out to MONITORING.
Indeed - and one thing I like with state machines architecture is that the code is usually easy to extend if we come up with another idea like adding a time based event. if you do it right, it does not lead to spaghetti code.
Yes. You could easily have arrows/transitions for both the "until a value is reached again" and "a 24 hour delay" event and then they each end up as separate, simple if-statements in the case SILENCED: state
Well probably late to the party.
Here's another version in Wokwi.
-jim lee
On behalf of Lucy the Wonder Cat I would respectfully request that projects making sounds at frequencies like 4000 Hz be avoided.
Using values of 500 and less will be acceptable.
TIA
a7
Oh, sorry about that. I just copied the OP's freq.
-jim lee
I tested your amended version of @J-M-L solution and it worked perfectly! Thank you very much @J-M-L and @alto777 for your assistance to help me solve my query.
