First, I'm sorry for my English, it's really bad, well, my problem is when I send the instruction Serial.print(); or Serial.write(); and have the shield active and connected, my Arduino send a nonsense text, I want and try a lot of things, but I don't see the problem, adjunct my code
#include <SoftwareSerial.h>
SoftwareSerial XBee(3,2);
XBee.begin(9600);
if (XBee.available()>0)
int dato = XBee.read();
Serial.write(char(dato));
thanks for your help, by some chance would you have an example about this?? I seen some programs related about this project but in all use the same structure
Finally, I was able to solve it. To do so, I had to change the char to string for data reading, and I used a counter to discard the data that didn’t work for me. Although the bit size depends on the type of data you want to preserve, I am attaching the code in which I use the XBee to read digital on/off signals, where you can see the logic I used so that the information could be read without any problem.
SoftwareSerial XBee(2,3);
char dato;
int cont;
unsigned long previousMillis=0;
const long interval=500;
XBee.begin(9600);
cont=0;
//desencriptado de paquetes de datos de XBee API//
if(cont < 20)
dato = XBee.read();
else if (cont == 20)
dato = XBee.read();
if(currentMillis - previousMillis >= interval)
previousMillis=currentMillis;
//Serial.print(String(dato,HEX));
if (String(dato,HEX)=="0")
Serial.print("off");
else if (String(dato,HEX)=="1")
Serial.print("on");
Serial.print(",");
Serial.print(" ");
//Serial.println(cont);
else if (cont > 20)
dato = XBee.read();
if (cont > 21)
cont=0;
cont++;
//Serial.println(String(dato,HEX));
The codes that are in the comments were used to verify which bit contained the data of interest and if the data was being received correctly. I clarify this to avoid any confusion.
I used string because the information is sent in hex, and the information can be a letter or a number, and I need to use the function hex to transform this package from hex to string
