My Arduino Leonardo does not seem to work correctly
So i just bought a Arduino Leonardo and connected it on my pc seems to work because it recognises it as "Arduino Leonardo" so when i tried Uploading but didnt seem to work i got an error
avrdude: Version"C:\Users\myusername\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\myusername\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 "-PCOM5" -b57600 -D "-Uflash:w:C:\Users\myusername3\AppData\Local\Temp\arduino\sketches\71570487F91002B1C6630EDBAC6FE9C2/Chinese-buttons-not-omron.ino.hex:i"
6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\myusername\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : avr109
     Overriding Baud Rate          : 57600
avrdude: ser_open(): can't open device "\.\COM5": The system cannot find the file specified.
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
It seems to work perfectly fine with my Uno but not with Leonardo
Before asking yes i enabled verbose output upload
If you can help it would be very appreciated
Thanks
Are you sure that you didn't confuse the port?
Your board is connected to the COM5?
Did you select the correct board in the tools menu? The Leonardo uses a different com-port for uploading then for normal use. The upload port should be detected automatically during upload. The Com port shown in the IDE for normal use is not existent during upload.
After i did i have another error ?
avrdude: Version 6.3-20190619
Copyright (c) 2000-2"C:\Users\myusername\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\myusername\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 "-PCOM8" -b57600 -D "-Uflash:w:C:\Users\myusername\AppData\Local\Temp\arduino\sketches\71570487F91002B1C6630EDBAC6FE9C2/Chinese-buttons-not-omron.ino.hex:i"
     Using Port                    : COM8
     AVR Part                      : ATmega32U4
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PA0
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : butterfly
     Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\myusername\AppData\Local\Temp\arduino\sketches\71570487F91002B1C6630EDBAC6FE9C2/Chinese-buttons-not-omron.ino.hex"
avrdude: writing flash (4382 bytes):
Writing | ################################################## | 100% 0.33s
avrdude: 4382 bytes of flash written
(I changed the com port btw)
Which error? What you posted is a log of a successful upload.
Oh yeah i just saw
then i guess my code is wrong ?
Ill check thank you
Maybe its debugging time now :smile: :smile:
