Hello, I'm a beginner and trying to to write some code to make an led flash and it gives my this error, here is my code.
error is "Compilation error: expected ')' before '=' token"
const int(RED, 13);
pinMode(RED, OUTPUT);
digitalWrite(RED, HIGH);
delay(300);
digitalWrite(RED, LOW);
delay(300);
That's not correct syntax. Try:
const int RED = 13;
The compiler will tell you what line it found that error on. Inspect that line for problems.
I have gotten pages of errors for a missing semicolon. When that happens go to the top of the error list and start there, it is usually in the first line that shows your program line number.
You can post the errors in code tags too. I got these when I tried compiling your code:
sketch.ino:1:14: error: expected ')' before ',' token
const int(RED, 13);
sketch.ino:1:16: error: expected unqualified-id before numeric constant
const int(RED, 13);
sketch.ino: In function 'void setup()':
sketch.ino:4:9: error: 'RED' was not declared in this scope
sketch.ino: In function 'void loop()':
sketch.ino:9:14: error: 'RED' was not declared in this scope
Error during build: exit status 1
They indicate bad syntax on that first line.
It should look more like the examples from https://docs.arduino.cc/language-reference/en/variables/data-types/int/ :
