Hello everyone,
I'm new here, and i'm discovering the wonderfull word of esp8266.
I'm using the board "UNO+WiFi R3 ATmega328P+ESP8266, 8Mb flash, USB-TTL CH340G, Micro-USB"
After several issues regarding the CH340 driver problem, find a micro-usb who allow datatransmission,
i tried to upload this sketch into my esp8266 using
the following DIP configuration 1,2,3,4 -> off and for 5,6,7,8 -> on
and for the board : "Generic ESP8266 module"
Serial.println("");
Serial.println(" Hello world !");
i get this
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 236020 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26729 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1496 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 900 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25616 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 265145 bytes (27%) of program storage space. Maximum is 958448 bytes.
Global variables use 28012 bytes (34%) of dynamic memory, leaving 53908 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port /dev/cu.usbserial-1420
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: e8:db:84:e4:45:4b
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0340
Compressed 269296 bytes to 197708...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (15 %)
Writing at 0x00008000... (23 %)
Writing at 0x0000c000... (30 %)
Writing at 0x00010000... (38 %)
Writing at 0x00014000... (46 %)
Writing at 0x00018000... (53 %)
Writing at 0x0001c000... (61 %)
Writing at 0x00020000... (69 %)
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 269296 bytes (197708 compressed) at 0x00000000 in 19.2 seconds (effective 112.2 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
but when i open the serial monitor and after press the MCU reset
i get this
i don't understand why because i use the good baud rate to visualise the information?
when i try after to upload this sketch to visualize the serial monitor using this
DIP configuration 1,2,3,4 ,7 -> off and for 5,6,8 -> on
i get this
so in the end i get the right answer "Hello World" but i don't understand why first i had to change the DIP confguration to obtain that, and i don't understand also why i still have this weird string before my "Hello World"
If someone could help me it would be great ![]()
thank you in advance
