My Keypad Sends something and doesnt stops
I cant send **** symbols to my arduino, i tested my keypad and it working with no problem, i think theres a problem in my code.
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte pin_rows[ROWS] = {10, 11, 12, 13}; //connect to the row pinouts of the keypad
byte pin_column[COLS] = {6, 7, 8, 9}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), ROWS, COLS, ROWS, COLS);
pinMode(2, OUTPUT); // set the LED pin as an output
Serial.begin(9600); // initialize serial communication
char key = keypad.getKey();
Serial.println(key);
if (key == '*') {
// the user entered the first digit of the code
char secondDigit = keypad.getKey(); // read the second digit
if (secondDigit == '*') {
  // the user entered "1A", so read the third digit
  char thirdDigit = keypad.getKey();
  if (thirdDigit == '*') {
    // the user entered "1A5", so read the final digit
    char fourthDigit = keypad.getKey();
    if (fourthDigit == '*') {
      // the user entered "1A5D", so turn on the LED
digitalWrite(2,HIGH);
digitalWrite(2,LOW);
delay(900);
delay(900);
delay(900);
delay(900);
delay(800);
delay(800);
delay(800);
delay(800);
delay(700);
delay(700);
delay(700);
delay(700);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(400);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(200);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(17);
delay(17);
delay(17);
delay(17);
Why did you post in the Uncategorised category of the forum when its title very clearly says
DO NOT CREATE TOPICS IN THIS CATEGORY
Your topic has been moved to the Programming category
In addition to posting in the wrong category you have not posted your code as advised
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
If the user entered a * as the second digit then they did not enter "1A", neither did they enter 1 as the first digit. Is the code wrong or the comment ?
The call to keypad.getKey() is probably returning NO_KEY (a.k.a: 0). Try "keypad.waitForKey()" to get the next key press.
Where i should use this command
Anywhere that you want to wait for a key as opposed to checking whether a key has been pressed and moving on whether or not a keypress has been detected
Thank you so much, its finished :slight_smile:
if (keypad.getKey() != NO_KEY)
// code to run when a key is pressed
EDITED... bad code
That doesn't wait for a key.
As i can see, you are taking the key and next you are printing it without asking if a key was pressed:
must be:
if (key) {
and similar with second digit
xakko
and like an old programmer i am, try to work with subrutines or functions. In the void loop just put the main action: wait for a key. once its happend, send to other subrutine:
  if (key) {
    keypressed(key);
void keypressed (char kp) {
it's just a suggestion
xakko
