My pressure sensor reading results are wrong
MPS20N0040D Barometric Pressure sensor displays a negative number result even though the sensor has not been applied pressure. is there a problem in my code or is my sensor problematic. for the module on this sensor HX710B, and the library that I use is HX710B-base_pressure_sensor.
library from roland pelayo
please help those of you who can solve my problem
#include "HX710B.h"
const int DOUT_Pin = D2;   // Pin data sensor
const int SCLK_Pin = D3;   // Pin clock sensor
HX710B pressure_sensor;
  pressure_sensor.begin(DOUT_Pin, SCLK_Pin, 128);  // Gunakan faktor penguatan default 128
  if (pressure_sensor.is_ready()) {
    Serial.print("Pascal: ");
    Serial.println(pressure_sensor.pascal());
    // Di sini Anda bisa melakukan sesuatu dengan data yang diperoleh dari sensor
    Serial.println("Pressure sensor not found.");
  delay(3000);
Sorry... I read the wrong library.
Are you certain your above lines are correct? The HX710B.h library example I read had this to create the object:
HX710B air_press(SCK_PIN, SDI_PIN);
if ( !air_press.init() )
If you apply pressure, readings are changing?
Why don't you use example sketch from Pelayos library?
D2,D3 suggests that you're not using an Uno.
So which Arduino are you using.
These cheap sensors have a large offset and temp drift.
You can calibrate the offset with an extra line at the end of setup().
pressure_sensor.set_offset(-7538000L);
My sensor needed -7538000L to get near zero Pascal without pressure.
Leo..
The code is from the sample library. but I changed it a little because it was problematic when compiling the code, when I applied pressure, the sensor reading changed or read
i don't use arduino but i use nodemcu esp8266
I believe what you are seeing is a zero offset error in the sensor. If this sensor is the one that has a range of 0 to 40kPa then 45 Pa is in the order of 0.1% error. Basically no error.
Also know a reading of 0 is difficult for many sensors due to the change in direction of the force.
Did you try:
Serial.println(pressure_sensor.pascal() + 43.83);
That's a 3.3volt-logic processor, so you should power the sensor from the 3.3volt pin of the ESP.
The line of code I gave you over-writes the offset that is already used in the library.
You can find it in line28 of the HX710B.h file (-540000).
Leo..
Exactly.
When we pick a sensor we should stop for a minute and try to understand how that specific sensor is working, what is the range that it can measure an so on. If this sensor has a range of 0-40000Pa, I'm sure it's not built to measure changes in 0-40Pa range, but fine to sense difference between 10kPa and 11kPa. Also the output is really just a number that we want it rappresentate, maybe you want this sensor to output 0 when no external load, or maybe 101kPa, the atmospheric pressure.
