I am a beginner in arduino.
I was creating a robot i connected all wires and uploaded the code as given below.
I think that arduino uno is not taking code and not responding but light is glowing.
#include <AFMotor.h>
#include <NewPing.h>
#include<Servo.h>
#define TRIGGER_PIN A1
#define ECHO_PIN A0
#define MAX_DISTANCE 300
#define IR A5
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
String voice;
Serial.begin(32256);
myservo.attach(10);
myservo.write(90);
pinMode(IR, INPUT);
int distance = sonar.ping_cm();
//int IR1 = digitalRead(IR);
//Serial.println(IR1);
if(Serial.available()>0) {
voice="";
delay(2);
voice = Serial.readString();
delay(2);
Serial.println(voice);
if (voice == "turn left") {
left();
}else if (voice == "left") {
left();
}else if(voice == "turn right") {
right();
}else if(voice == "right") {
right();
while(voice == "move forward") {
forward();
while(voice == "move backward") {
backward();
void forward() {
if(distance < 10){
Stop();
voice="";
}else {
motor1.setSpeed(255);
motor1.run(FORWARD);
motor2.setSpeed(255);
motor2.run(FORWARD);
motor3.setSpeed(255);
motor3.run(FORWARD);
motor4.setSpeed(255);
motor4.run(FORWARD);
void backward() {
int IR_Sensor = digitalRead(IR);
if(IR_Sensor == 0) {
Stop();
voice="";
}else {
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void left() {
myservo.write(180);
myservo.write(90);
delay(700);
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void right() {
myservo.write(0);
myservo.write(90);
delay(700);
void Stop() {
It is not working .
here is its image below
Please advice me .
Thank you
Chirayu
