Hello, this Is my first time posting here.
I am working on a project(bluetooth controlled car). I am using the adafruit motor shield V1. After connecting everything to arduino and uploading my code>>
/******************* Robot Remote Control Mode ********************/
// include the Adafruit motor v1 library
#include <AFMotor.h>
AF_DCMotor MotorFR(1); // Motor for drive Front Right on M1
AF_DCMotor MotorFL(2); // Motor for drive Front Left on M2
AF_DCMotor MotorBL(3); // Motor for drive Back Left on M3
AF_DCMotor MotorBR(4); // Motor for drive Back Right on M4
const int buzPin = 2; // set digital pin 2 as buzzer pin (use active buzzer)
const int ledPin = A5; // set digital pin A5 as LED pin (use super bright LED)
int valSpeed = 255;
void setup(){
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Robot Remote Control Mode");
Serial.println("READY TO GO");
pinMode(buzPin, OUTPUT); // sets the buzzer pin as an Output
pinMode(ledPin, OUTPUT); // sets the LED pin as an Output
// Set the speed to start, from 0 (off) to 255 (max speed)
MotorFL.setSpeed(valSpeed);
MotorFR.setSpeed(valSpeed);
MotorBL.setSpeed(valSpeed);
MotorBR.setSpeed(valSpeed);
// turn off motor
MotorFL.run(RELEASE);
MotorFR.run(RELEASE);
MotorBL.run(RELEASE);
MotorBR.run(RELEASE);
while (Serial.available() > 0) {
char command = Serial.read(); // gets one byte from serial buffer
Serial.println(command);
switch(command){
case 'F': // move forward
SetSpeed(valSpeed);
MotorFL.run(FORWARD);
MotorFR.run(FORWARD);
MotorBL.run(FORWARD);
MotorBR.run(FORWARD);
case 'B': // move backward
SetSpeed(valSpeed);
MotorFL.run(BACKWARD);
MotorFR.run(BACKWARD);
MotorBL.run(BACKWARD);
MotorBR.run(BACKWARD);
case 'R': // turn right
SetSpeed(valSpeed);
case 'L': // turn left
SetSpeed(valSpeed);
case 'G': // forward left
MotorFL.setSpeed(valSpeed/4);
MotorBL.setSpeed(valSpeed/4);
case 'H': // backward left
case 'I': // forward right
MotorFR.setSpeed(valSpeed/4);
MotorBR.setSpeed(valSpeed/4);
case 'J': // backward right
case 'S': // stop
case 'V': // beep buzzer
digitalWrite(buzPin, HIGH);
delay(150);
digitalWrite(buzPin, LOW);
delay(100);
delay(250);
case 'W': // turn light on
digitalWrite(ledPin, HIGH);
case 'w': // turn light off
digitalWrite(ledPin, LOW);
case '0': // set speed motor to 0 (min)
SetSpeed(0);
case '1': // set speed motor to 30
SetSpeed(30);
case '2': // set speed motor to 55
SetSpeed(55);
case '3': // set speed motor to 80
SetSpeed(80);
case '4': // set speed motor to 105
SetSpeed(105);
case '5': // set speed motor to 130
SetSpeed(130);
case '6': // set speed motor to 155
SetSpeed(155);
case '7': // set speed motor to 180
SetSpeed(180);
case '8': // set speed motor to 205
SetSpeed(205);
case '9': // set speed motor to 230
SetSpeed(230);
case 'q': // set speed motor to 255 (max)
SetSpeed(255);
// function for setting speed of motors
void SetSpeed(int val){
valSpeed = val;
MotorFL.setSpeed(val);
MotorFR.setSpeed(val);
MotorBL.setSpeed(val);
MotorBR.setSpeed(val);
I then open the serial monitor only to see a totally different thing from what I was expecting. Please I need help to understand what's wrong.
