My serial port si not reading
Dear All,
The condition _cell.available() retunr false and I do not understand why
        if(_cell.available() != 0){    // if there are data in the UART input buffer, reads it and checks for the asnwer
            response[x] = _cell.read();
            Serial.print(response[x]);
            x++;
            Serial.print(F("Response"));
            Serial.println(response);
            Serial.print(F("Expected answer"));
            Serial.println(expected_answer);
            if (strstr(response, expected_answer) != NULL)    // check if the desired answer (OK) is in the response of the module
                answer = 1;
        }else{
        if(_debug){
         Serial.println(F("No data in UART"));
In my .ino file I do have this
// GENERAL
int debug = true;
int pinToPowerOnModule = 8;
int dtr = 7;
// LED
int green = 12;
#define MSEC 500
#define MSEC_FAST 150
// SERIAL
int baud_rate = 9600;
int rxpin = 2;
int txpin = 3;
Sim908 sim908(rxpin, txpin, baud_rate, pinToPowerOnModule, debug, dtr);
My constructor look like:
Sim908::Sim908(int rxpin, int txpin, int baud_rate, int pinToPowerOnModule, int debug, int dtr)
	pinMode(pinToPowerOnModule, OUTPUT);
	pinMode(dtr, OUTPUT);
	_pinToPowerOnModule = pinToPowerOnModule;
	_debug = debug;
	_baud_rate = baud_rate;
	_dtr = dtr;
	_rxpin = rxpin;
	_txpin = txpin;
I also have an initialize function
void Sim908::initializeSim908()
	//digitalWrite(_dtr,LOW);
	SoftwareSerial _cell(_rxpin,_txpin);
	_cell.begin(_baud_rate);
	powerOnSim908();
in My Sim908.h file, I declare _call like this:
  Sim908.h - Library
#ifndef Sim908_h
#define Sim908_h
#include <SoftwareSerial.h>
#include "Arduino.h"
class Sim908{
	private:
		int _pinToPowerOnModule;
		//Stream* _cell;
		SoftwareSerial _cell;
		//SoftwareSerial* _cell;
		int _debug;
		int _baud_rate;
		int _dtr;
		int _rxpin;
		int _txpin;
	public:
		Sim908(int rxpin, int txpin, int baud_rate, int pinToPowerOnModule, int debug, int dtr);
		//Sim908(SoftwareSerial cell, int baud_rate, int pinToPowerOnModule, int debug, int dtr);
		void initializeSim908();
		void powerOnSim908();
		int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout);
		void blinkLed(int lPin, int nBlink, int msec);
#endif
The terminal display that error message:
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp: In constructor 'Sim908::Sim908(int, int, int, int, int, int)':
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp:6: error: no matching function for call to 'SoftwareSerial::SoftwareSerial()'
/Applications/Arduino.app/Contents/Resources/Java/libraries/SoftwareSerial/SoftwareSerial.h:83: note: candidates are: SoftwareSerial::SoftwareSerial(uint8_t, uint8_t, bool)
/Applications/Arduino.app/Contents/Resources/Java/libraries/SoftwareSerial/SoftwareSerial.h:48: note: SoftwareSerial::SoftwareSerial(const SoftwareSerial&)
NB: In my Sim908.h and Sim908.cpp I added that line #include "SoftwareSerial.h"
So _cell.available or _cell.read should work as if in my .ino file, I would use that?
SoftwareSerial cell(rxpin,txpin);
cell.begin();
cell.available()
cell.read();
Do you see somethink wrong?
Thank a lot
Anything that interacts with hardware should be in your initialise method, not in the constructor.
class Sim908{
	private:
cell.begin();
cell.available()
cell.read();
You are creating a private instance of SoftwareSerial inside your object, and declaring / using a global instance in your program?
I thought the earlier version of your software passed a pointer to the global instance into the constructor. Why have you changed?
Dear Hackscribe
Thank for your advise.
I moved this to the initializeSim908 function
Now my constructor look like
	_debug = debug;
	_dtr = dtr;
	_rxpin = rxpin;
	_txpin = txpin;
What do you mean? For now _cell is only using in my class
I followed you advise when you told me to remove the begin() from the method
Below there is _cell.begin. It the reason why I make it private
class Sim908{
	private:
Here is my initializeSim908 function
	//powerOnSim908();
What it suprise me, the error message state
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp:7: error: no matching function for call to 'SoftwareSerial::SoftwareSerial()'
but the line Sim908.cpp:7 is my constructor :
Sim908::Sim908(int rxpin, int txpin, int baud_rate, int pinToPowerOnModule, int debug, int dtr) // line 7
	_debug = debug;
	_dtr = dtr;
	_rxpin = rxpin;
	_txpin = txpin;
and there is nothing about SoftwareSerial!!
I think my error come from _cell but I can find it. Then I comment the code about the pointer in order to be concentred on the initializeSim908 function. When this part will be sure and working as if I would have done in my ino file.
cell.begin();
cell.available()
cell.read();
Previosly I did like just above (in the ino file) and it worked, but now I would like to move
cell.begin();
in a library and to be able to use (in the Sim908.cpp file)
_cell.available(), _cell.read as I was doing in an ino file. This is my main issue :cold_sweat:
Do you understand me?
Thank for your help
Quick thing to change.
You should use _pinToPowerOnModule and _dtr here
I'll look at the rest of your post.
Ho yep, that's correct. I changed like this
	pinMode(_pinToPowerOnModule, OUTPUT);
	pinMode(_dtr, OUTPUT);
	//powerOnSim908();
Thank a lot. I hope I provided enough information
I changed like this
That will never work. The local variable, _cell, goes out of scope when the constructor ends.
OK, I now understand what you meant by this ...
cell.begin();
cell.available()
cell.read();
In your library .h file, you have ...
class Sim908{
	private:
To initialise the instance, you need to change your constructor to this in your library .cpp file:
Sim908::Sim908(int rxpin, int txpin, int baud_rate, int pinToPowerOnModule, int debug, int dtr): _cell(rxpin, txpin)
	_debug = debug;
	_dtr = dtr;
	_rxpin = rxpin;
	_txpin = txpin;
Hello,
Ok this very interessting because I already that exemple
GSM::GSM():_cell(_GSM_TXPIN_,_GSM_RXPIN_),_tf(_cell, 10),_status(IDLE)
And it compile without error!!!!!
Greate, I am ging to upload my code and see the result. I keep you informed :grin:
Ca marche vachement mieux. Bravo. Toujours un petit bug, mais je vais chercher d'abord... Well done
Ok, it's work very much better, but there is still a small problem aroud _cell.
I explain step by step.
	// define the role of pin 8 and 7
        //pu pin 7 the LOW (dtr)
        // Begin _cell (Serial) pin 2 and 3
        //Powerup SIM908
	powerOnSim908();
initializeSim908 call powerOnSim908 funtion
   uint8_t answer=0;
     // Put up pin 8 fro 3 sec to powerup SIM908
    digitalWrite(_pinToPowerOnModule,HIGH);
    delay(3000);
    // Put the pin 8 back down
    digitalWrite(_pinToPowerOnModule,LOW);
     if(_debug){
		Serial.print(F("Powering up SIM908.\n"));
    while(answer == 0){     // Send AT every two seconds and wait for the answer
    	answer = sendATcommand("AT", "OK", 2000l);
    if(_debug){
	    Serial.print(F("SIM908 is powered on!\n"));
powerOnSim908 call antoher funtion : sendAtCommand in order to continur while OK is received.
The problem is from that moment
int8_t Sim908::sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    // For debugin. It display a correct information
   if(_debug){
   	Serial.print("WAITING FOR ANSWER \n");
       Serial.print("Expected answer: ");Serial.println(expected_answer);
       Serial.print("Timeout: ");Serial.println(timeout);
    memset(response, '\0', 100);    // Initialice the string
    delay(100);
    while( _cell.available() > 0) _cell.read();    // Clean the input buffer
    if (ATcommand[0] != '\0')
       // This is displaying
    	if(_debug){
        	Serial.print("Command: ");
        	_cell.println(ATcommand);    // Send the AT command
        	Serial.println("");
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
            // THE PROBLEM IS HERE
            x++;
           // SEE MY COMMENT BELOW
			Serial.print(F("*****************\n"));
			Serial.print(F("RESPONSE : "));
            Serial.print(F("EXPECTED ANSWER : "));
                answer = 1;
                 Serial.println(F("ANSWER RECEIVED : "));
                 Serial.println(F(""));
        }else{
        if(_debug){
         //Serial.println(F("No data in UART"));
    }while((answer == 0) && ((millis() - previous) < timeout));    // Waits for the asnwer with time out
if(_debug){
Serial.println("");
Serial.print("Answer : ");
Serial.println(answer);
Serial.println("");
    return answer;
In my point of view this does not work
I think _cell.read() can not read correctly.
In my code I added this for debuging
and Serial.print(F("RESPONSE : ")); is displaying "xü" like this, while it waiting for OK
RESPONSE : x
EXPECTED ANSWER : OK
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
RESPONSE : xü
External module is running at a different baud rate from what you expect, maybe?
Hello
@Hackscribble
no, all are at 9600.
@PaulS and and @Hackscribble ( and all who want)
You helped me and I thank you again, but I can not solve and make it working, this because I am not a expert.
Would you be agree to take a bit of your time to see my complete code? It will really help me because I know nobody, in my town or work, who know Arduino or C++.
I Put my files in https://github.com/pierrot10/sim908 and I added some comment to read how and where I see the problem
. I think it around the _cell variable and IsStringReceived() function
I will really appreciate your help :o)
I am sure, I will be able to adapt all of my other functions quickly when it will be solved.
You could use a test program like this, not using the library, to send "AT" to the module and print what characters it returns. This would eliminate hardware issues, baud rate as problems.
int dtr = 7;
int rxpin = 2;
int txpin = 3;
SoftwareSerial testCell(rxpin, txpin);
  Serial.println("Test started");
  digitalWrite(pinToPowerOnModule, LOW); // should default to this, but just being careful
  digitalWrite(dtr, LOW);
  testCell.begin(baud_rate);
  digitalWrite(pinToPowerOnModule, HIGH);
  delay(3000);
  testCell.println("AT");
  Serial.println("Command sent");
  if (testCell.available())
    Serial.print("Character received: >>");
    Serial.write(testCell.read());
    Serial.println("<<");
Hello.
Your test code work fine and it return reading text between the >> <<.
I also tryed to have the same result using a library and it works
SoftwareSerialTest.ino
#include <Morse.h>
Morse morse(4800);
int dtr = 7;
int baud_rate = 4800;
int rxpin = 2;
int txpin = 3;
  delay(3000);
   morse.begin();
  morse.testSerial();
Morse.h
#ifndef Morse_h
#define Morse_h
//#include "WProgram.h"
#define RXPIN 2
#define TXPIN 3
class Morse
  public:
    Morse(int pin);
    void begin(void);
    int baute_rate;
    void testSerial(void);
  private:
    int _baute_rate;
#endif
Morse.cpp
#include "Morse.h"
Morse::Morse(int baute_rate):_cell(RXPIN,TXPIN)
  _baute_rate = baute_rate;
void Morse::begin(void){
	_cell.begin(_baute_rate);
	_cell.println("AT");
void Morse::testSerial(void){
	if (_cell.available())
    Serial.write(_cell.read());
  }else{
  	//Serial.println("none");
This is the result
noneTest started
Command sent
Character received: >>A<<
Character received: >>T<<
Character received: >>O<<
Character received: >>K<<
Character received: >>C<<
Character received: >>a<<
Character received: >>l<<
Character received: >> <<
Character received: >>R<<
Character received: >>e<<
Character received: >>d<<
Character received: >>y<<
Character received: >>G<<
Character received: >>P<<
Character received: >>S<<
Would you have a comment?
I was used to use a function the read the return display but it's mess.
Would you have recommandation to return true when we got "GPS ready", for exple?
May be I will open a new post and search for a solution
Many thank for your help
Cheers
