My servo not activating
So I am working on a circuit that activates a servo motor if enough current is inputted. But my servo is not moving. What am I doing wrong?
Here is the code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
const float minimum_current = 0;
    myservo.attach(8);  // attaches the servo on pin 9 to the servo object
    int current = analogRead(0);
    if(current >= minimum_current) {
        //  Pressure is in range. Move the servo.
        for(pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 180 degrees
            // in steps of 1 degree
            myservo.write(pos);              // tell servo to go to position in variable 'pos'
            delay(5);                       // waits 15ms for the servo to reach the position
This is what my circuit looks like:
If you have a problem, then isolate that problem and try to fix it. Remove everything that introduces more complexity.
Remove everything from the Arduino Uno board. Connect the servo to 5V, GND and pin 8. Verify that you have the right pins for the servo motor. Make a small test sketch that only uses the servo motor.
Just move the Servo motor:
  myservo.write(0);
  myservo.write(180);
I think that you have the wires wrong for the Servo motor:
  • Servo Brown wire = GND
  • Servo Red wire = 5V
  • Servo Yellow/Orange wire = signal wire to pin 8.
I cannot follow your circuit, it is not clear. Post an annotated schematic showing exactly how you have wired it. Be sure to show power, ground, and power(s) sources. What is that thing your finger is on, post a link to technical information on that.
Thing is ACS712 current sensor: https://www.amazon.com/HiLetgo-ACS712-Current-Sensor-Module/dp/B07SPRL8DL
And why is there a resistor ( or something else? ) between the UNO and the servo? Usually servos are connected directly as @Koepel already pointed out.
The way your sketch is written the servo will immediately move to the 90° position and then stay there. No matter what current is read, it's always >= 0 (analogRead(0) returns a value of 0-1023, and minimum_current is set to 0), so every instance of loop() it will move to 90° (and take a mere 0.45 seconds to do so, meaning it'll basically just stay there).
This provided the servo is wired correctly, of course. The current sensor is not doing anything, really - even if not connected this will be the result.
Thank you so much! I'll try that right now!
Yes it works, but then does this mean that the wiring for the ammeter is wrong? I connected the ammeter to GND, 3.3V and A0.
I added the resistor since when I connected the servo directly, my servo started heating up like crazy.
This is the plan I drew out:
The thing I am holding is the ACS712 current sensor. @Koepel has the link below your post.
I took a more close up photo of my wiring. I hope this helps solve my problem.
The brown wire is not connected to GND, the yellow/orange wire is not connected to pin 8 and there is a resistor on the breadboard.
Thank you! I’ll connect the wires to pin 8 and GND but without the resistors my servos will burn. Are you sure that I should remove the resistor?
If the servo gets hot without the resistor, there ist something else wrong.
With the battery in series with the ground connection your servo will probably feedback into the Arduino and fry it. How are you powering it, I see nothing on the schematic that shows it other then the 9V battery.
So what could I be doing wrong?
Use Pin 9 instead.
Its ok now! My circuit works perfectly! Thank you for helping me!
Thank you very much for all those which gave me an advice! Now my circuit functions perfectly! Thank you so much for helping me!
What was the actual fix? pin 9?
