In the previous version (0.3.2) of App Lab the following application (in every 10 sec interval MPU asks the MCU to blink LED3_R for five times) was working well. In the current version (0.4.0) of App Lab which was automatically updated, the program does not run. This is the error message: (Any program that involves Bridge.call()/provide()/notify() does not run!)
python provisioning
python downloading
Network blink-led3_r-for-five-times-requested-by-mpuworking_default Creating
Network blink-led3_r-for-five-times-requested-by-mpuworking_default Error
failed to create network blink-led3_r-for-five-times-requested-by-mpuworking_default: Error response from daemon: could not find an available, non-overlapping IPv4 address pool among the defaults to assign to the network
exit status
Please advice what should I do now?
Sketch:
#include "Arduino_RouterBridge.h" //provides data excage facilities for UART2
pinMode(LED3_R, OUTPUT);
digitalWrite(LED3_R, HIGH); //HIGH state means LED is OFF
Bridge.begin(); //enables UART2's loe level functions
Bridge.provide("led_blink", led_blink); //led_blin is the name of ISR
void led_blink(byte count) //ISR when TX2 is ready; count comes from MPU
for(int i = 0 ; i<count; i++)
digitalWrite(LED3_R, LOW);
Script:
from arduino.app_utils import *
import time
last_time = 0 # the last time LED did blinking
interval = 10 # Interval in seconds
def loop():
global last_time
current_time = time.time() # Get current time in seconds
if current_time - last_time >= interval: # Check if 10 seconds have passed
Bridge.call("led_blink", 5) #comand string, five times to blink
last_time = current_time
App.run(user_loop=loop) # Start the App Lab loop`
I would downgrade the STM core to 52, 53 seems to kill the bridge..
I used the command from this post..
They need to be run from a terminal or shell..
good luck.. ~q
Start Arduino App Lab and connect it to your UNO Q board (if using the board in PC hosted mode).
If you are using the board in PC hosted mode, click the >_ ("Connect to the board's shell") icon near the bottom left hand corner of the Arduino App Lab window. Otherwise, open the terminal via the desktop menu.
A terminal window will open.
Type the following command in the terminal window:
arduino-app-cli system cleanup
Press the Enter key.
A message will appear:
Running cleanup...
Wait for the cleanup process to finish.
Close the terminal window.
Now try starting your App again. Hopefully this time it will start up successfully.
The first time you start an App, a Docker container is created. This container provides a dedicated environment in which the App's Python script is executed, isolated from the environment of the UNO Q's Linux operating system.
A dedicated Docker network is created for each App, in order to allow network communication.
Docker allocates a subnet to the network from an address pool:
This pool is quite limited, so can be quickly exhausted as you create more Apps. When the pool is exhausted, starting a new App fails with the error message you encountered, due to not being able to create the network for the App's container:
The arduino-app-cli system cleanup command removes all containers that are not in use by a running App.
So by running these commands in sequence, you free up space in the address pool, and thus make it possible for a new network to be created for the App you are trying to start.
The Arduino developers are adding the network pruning operation to the arduino-app-cli system cleanup command of the Arduino App CLI tool:
In addition to being convenient to those users who work directly with Arduino App CLI from the command line, this also makes the functionality available to Arduino App Lab (since Arduino App CLI serves as its backend).
