MySQL send blocking Interrupt
I am building a monitor for my water usage that updates a mysql table with the stats from a flowmeter. I am currently using a button to simulate the pulse from the flowmeter for testing. I set up the pulse as an interrupt so I count all the pulses while code is running. However, the sketch misses any pulses that happen while it is sending the mysql data. This is not critical as I will only send the data periodically, but I would rather not miss pulses. Any advice?
Just FYI, the sketch also monitors how long the water has been running and shuts it off if it runs too long.
I am using an Arduino UNO R4. I am also very new to Arduino programming so any advice on other issues with my code is welcome.
Sketch code:
// Include the RTC library
#include "RTC.h"
//Include the NTP library
#include "arduino_secrets.h"
#include <NTPClient.h>
#include <WiFiS3.h>
#include <WiFiUdp.h>
#include <ArduinoHttpClient.h>
#include <ArduinoJson.h>
#include <ArduinoJson.hpp>
#include "wifiTime.h"
#include "Button.h"
#include "FlowCheck.h"
#include "ServerPing.h"
#include "mysqlSend.h"
#define BUTTON_PIN 5
Button button1(BUTTON_PIN);  //define pin for tester pulde
byte sensorInterrupt = 2; //flow sensor interrupt
volatile byte pulseCount; //pulse counter
bool buttonStatus ;
flowCheck flowCheck;  //establish flow check
serverPing serverPing("connected.homeseer.com"); //establish homeseer connection
int oldHour;  //establish variable to check for new hour
int oldDay;  //establish variable to check for new day
unsigned long timerCheckMs;  //establish variable to check timer loop
unsigned long timerTimeMs = 30000; //set timer loop  to 15 seconds
  while (!Serial);  //wait for serial
  connectToWiFi(); //connect to wifi
//start RTC and set time
  RTC.begin();
  time_update(-8);
  RTC.getTime(currentTime);
  Serial.println("The RTC is updated: " + String(currentTime));
//grab homeseer variables
  String Pstatus = serverPing.statusProperty();
  Serial.print("status property = : ");
  Serial.println(Pstatus);
  String vstatus = serverPing.statusMonitor();
  Serial.println(vstatus);
  //check wifi
  if (wifiStatus != WL_CONNECTED) {
    Serial.println("Wifi DISCONNECTED. Trying to reconnect...");
    connectToWiFi();
  flowCheck.waterRunMaxSec[1] = 50;
  pulseCount = flowCheck.check(pulseCount);  //run flow check
///basic timer
  if (millis() - timerCheckMs > timerTimeMs) {
    timerCheckMs = millis();
    Serial.println("");
    Serial.println(">>>>>>>>TIMER LOOP>>>>>>>>");
    String sqlColumns = "hour,mon_status,volume";
    String sqlValues = "'1','val2','" + String(flowCheck.volumeDay) + "'";
    querySend(sqlColumns,sqlValues); //send data to mysql table
  //////TIME BLOCKS
    RTCTime currenttime;  //establish current time variable
    RTC.getTime(currenttime); //set current time variable
  //hour block
    int nowHour = currenttime.getHour() ;
    if( nowHour != oldHour ){
        oldHour = nowHour;
        ///run hourly tasks
  //day block
    int nowDay = currenttime.getDayOfMonth() ;
    if( nowDay != oldDay ){
        oldDay = nowDay;
         ///run daily tasks
        time_update(-8);  //update RTC time once daily
///button pulse function
  if (button1.isPressed()) {
    if(buttonStatus){
    }else{
      pulseCount += 1;
      buttonStatus = true;
  }else{
    buttonStatus = false;
mysqlSend.h that handles the mysql request
#include <Arduino.h>
#include <WiFiS3.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
char user[] = SECRET_MYSQL_USER;
char password[] = SECRET_MYSQL_PASS;
void querySend(String sqlColumns,String sqlValues)
    byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
    IPAddress server_addr(XXX,XXX,XXX,XXX);  // IP of the MySQL *server* here
    // Sample query
String base_s = "INSERT INTO XXXXXXXXX.6556_Irr_Hr (" + sqlColumns + ") VALUES (" + sqlValues + ")";
const char *INSERT_SQL = base_s.c_str();
    WiFiClient client;
    MySQL_Connection conn((Client *)&client);
    Serial.println("Connecting...");
     if (conn.connect(server_addr, 3306, user, password)) {
    Serial.println("Connection failed.");
    Serial.println("Recording data.");
      // Initiate the query class instance
      MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
      // Execute the query
      cur_mem->execute(INSERT_SQL);
      // Note: since there are no results, we do not need to read any data
      // Deleting the cursor also frees up memory used
      delete cur_mem;
Thanks!
Which lines in your code do that?
yup. I thought i did that, but it looks to be a simple button press. I guess that answers why it was missing it when the sketch was working on something else. Thanks!
Just to make things clear to anyone finding this topic later, was MySQL send blocking Interrupt?
No, MySQL send was not blocking the Interrupt as there was not an actual interrupt being used in the sketch. Thanks again for your help.
