Mystery warnings from compiler
I'm working on SD code, and the code for the card init compiles successfully, but with extended warning messages that say I'm doing something I don't think I'm doing. This is obviously a case of my not knowing what I'm doing in C++. If anyone can help me out, I would appreciate it. Below are the warnings, and the code.
C:\Arduino\Portable\sketchbook\MySD\MySD.ino: In function 'byte initCard()':
C:\Arduino\Portable\sketchbook\MySD\MySD.ino:67:19: warning: invalid conversion from 'int' to 'unsigned char*' [-fpermissive]
     t = sendCmd(58);
C:\Arduino\Portable\sketchbook\MySD\MySD.ino:91:6: note:   initializing argument 1 of 'byte sendCmd(unsigned char*)'
 byte sendCmd (unsigned char *cmd) {
C:\Arduino\Portable\sketchbook\MySD\MySD.ino:79:19: warning: invalid conversion from 'int' to 'unsigned char*' [-fpermissive]
     t = sendCmd(16);
byte CSpin = 10;
byte i,j,k,t,z;
byte rIn, SDHC;
bool type2;
unsigned long prevmillis;
byte CSDELAY = 14;
unsigned char CMD0[]  = {0x40,0,0,0,0,0x95};              //intialization commands
unsigned char CMD8[]  = {0x48,0,0,1,0xAA,0x87};
unsigned char CMD16[] = {0x50,0,0,2,0,0x15};
unsigned char CMD55[] = {0x77,0,0,0,0,0x65};
unsigned char CMD411[]= {0x69,0,0,0,0,0xE5};
unsigned char CMD412[]= {0x69,0x40,0,0,0,0x77};
unsigned char CMD12[] = {0x4C,0,0,0,0,0x61};
unsigned char CMD58[] = {0x7A,0,0,0,0,0xFD};
  delay(3000);
  Serial.println("Starting...");
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(12, INPUT_PULLUP);
  SPCR = (1 << SPE) | (1 << MSTR) | (1 << SPR1);   //250k
  z = initCard();
  Serial.println (z);
byte initCard() {
  digitalWrite(CSpin, HIGH);
  for (k = 0; k< 10; k++) {
    GetByte();
  digitalWrite(CSpin, LOW);
  delay(100);
  for (k = 10; k > 0 ; k--) {
    t =  sendCmd(CMD0);
    if (t == 1) break;
  if (t != 1) return 1;
  t = sendCmd(CMD8);
  if (t == 1) {
    for (k = 0; k < 4; k++) {
      InByte();
    if (rIn = 0XAA) type2 = true;
    else return 2;
  else if (t == 5) type2 = false;
  else return 3;
  prevmillis = millis();
  while (1) {
    if (sendCmd(CMD55) == 5) return 4;
    if (type2 == false) t = sendCmd(CMD411);
    else t = sendCmd(CMD412);
    if (t == 0) break;
    if ((millis() - prevmillis) > 2000) return 5;
  for (k = 10; k > 0; k--) {
    t = sendCmd(58);              // should be (CMD58)
    if (t != 0) continue;
    SDHC = GetByte();
    TM1();
    if ((SDHC & 0x80) == 0) continue;
    SDHC &= 0x40;       // flag not zero if SDHC
  if (k == 0) return 6;
  if (SDHC == 0) {
    t = sendCmd(16);                /// should be (CMD16)
    if (t != 0) return 7;
  return 0;
void TM1() {
  InByte();
  InByte();
  InByte();
  GetByte();
  digitalWrite (CSpin,HIGH);
  Delay();
  digitalWrite (CSpin,LOW);
  Delay();
  for (i = 0; i < 6; i++) {
    SPDR = cmd[i];
    while (!(SPSR & (1 << SPIF)))
    rIn = SPDR;
  InByte();
  return rIn;
void InByte() {
  for (i = 0; i < 11; i++) {
    rIn = GetByte();
    if (rIn != 0xFF) break;
byte GetByte () {
  SPDR = 0xFF;
  while (!(SPSR & (1 << SPIF)));
  return SPDR;
void Delay(){
  for (i = 0; i < CSDELAY; i++);
I think you are missing an include, it doesn't compile as is.
The whole point of the exercise is not to have any includes. The code compiles as is on my IDE v1.8.8, except for the warning messages:
Sketch uses 2868 bytes (9%) of program storage space. Maximum is 30720 bytes.
Global variables use 240 bytes (11%) of dynamic memory, leaving 1808 bytes for local variables. Maximum is 2048 bytes.
The sendCmd() function expects an unsigned char pointer, you are giving it an integer as the argument.
What board?
I don't have any problem compiling on an UNO.
In addition to the errors with sendCmd(), line 50 has an error with the if statement:
Yes, and I did that twice. Thanks very much. I don't know how long I would have looked at that without seeing it. I'll note the bad spots in the code in post 1.
A Nano, with an old bootloader.
Classic one:
if (rIn == 0XAA) type2 = true;
Strictly this is not an error... it simply will not do what you expect...
Please note that each error message indicates the line number of your sketch where the error is located.
