Nano 33 BLE IMU Service
Hello,
Does anyone know why my board doesn't initialize IMU service?
This is the code
Thanks!!
#include <ArduinoBLE.h>
#include <Arduino_BMI270_BMM150.h>
// Set the same service UUID as in the Peripheral Device
const char* deviceServiceUuid = "b83b6b32-0d38-45da-9a65-73eecc736b17";
const char* AccXCharUuid = "22128dec-f7bc-4c21-a329-c13449221777";
const char* AccYCharUuid = "677314b1-6d7d-4b38-8e37-0a3d24538c01";
const char* AccZCharUuid = "648ae827-f439-4038-a8ed-88e67b2cbb33";
const char* GyroXCharUuid = "07c120ff-3915-410b-9c45-c84533e674df";
const char* GyroYCharUuid = "17a45678-jj34-5678-1234-56789ab34ef5";
const char* GyroZCharUuid = "9f345678-dd34-5678-1234-56789a67def6";
float x,y,z,gx,gy,gz;
double accelX=0;
double accelY=1;
double accelZ=0;
double gyroX=0;
double gyroY=0;
double gyroZ=0;
BLEService IMUService(deviceServiceUuid);
BLEDoubleCharacteristic AccXChar(AccXCharUuid, BLERead | BLENotify);
BLEDoubleCharacteristic AccYChar(AccYCharUuid, BLERead | BLENotify);
BLEDoubleCharacteristic AccZChar(AccZCharUuid, BLERead | BLENotify);
BLEDoubleCharacteristic GyroXChar(GyroXCharUuid, BLERead | BLENotify);
BLEDoubleCharacteristic GyroYChar(GyroYCharUuid, BLERead | BLENotify);
BLEDoubleCharacteristic GyroZChar(GyroZCharUuid, BLERead | BLENotify);
  while (!Serial);
  if (!BLE.begin()) {
    Serial.println("Starting Bluetooth failed!");
    while (1);
  Serial.println("BLE inicializado!");
  if (!IMU.begin()) {
    Serial.println("Failed to initialize IMU!");
    while (1);
  Serial.println("IMU inicializado!");
  BLE.setLocalName("Nano 33 BLE");
  BLE.setAdvertisedService(IMUService);
  IMUService.addCharacteristic(AccXChar);
  IMUService.addCharacteristic(AccYChar);
  IMUService.addCharacteristic(AccZChar);
  IMUService.addCharacteristic(GyroXChar);
  IMUService.addCharacteristic(GyroYChar);
  IMUService.addCharacteristic(GyroZChar);
  BLE.addService(IMUService);
  BLE.advertise();
  Serial.println("IMU Peripheral (Sending Data)");
  BLEDevice central = BLE.central();
  if (central) {
    if (central.connected()) {
      Serial.println("Connected to central device");
      Serial.print("Device MAC address: ");
      Serial.println(central.address());
      Serial.println("Disconnected from central device");
  if (IMU.accelerationAvailable()) {
    IMU.readAcceleration(x, y, z);
    accelX = x;
    accelY = y;
    accelZ = z;
    Serial.print("x: ");
    Serial.print(x);
    Serial.print(", y: ");
    Serial.print(y);
    Serial.print(", z: ");
    Serial.println(z);
  if (IMU.gyroscopeAvailable()) {
    IMU.readGyroscope(gx, gy, gz);
    gyroX = gx;
    gyroY = gy;
    gyroZ = gz;
    Serial.print("gx: ");
    Serial.print(gx);
    Serial.print(", gy: ");
    Serial.print(gy);
    Serial.print(", gz: ");
    Serial.println(gz);
  AccXChar.writeValue(accelX);
  AccYChar.writeValue(accelY);
  AccZChar.writeValue(accelZ);
  GyroXChar.writeValue(gyroX);
  GyroYChar.writeValue(gyroY);
  GyroZChar.writeValue(gyroZ);
  delay(50);
What exact model of Nano 33 BLE do you have? Is it a BLE Sense? Rev2?
Perhaps it is a board which uses a LSM9DS1.
#include <Arduino_LSM9DS1.h>
BLE,
BLE Rev. 2,
BLE Sense,
BLE Sense Rev. 2
Whichever - it's on the back of the unit (or the box in came in).
It's a Nano 33 BLE Rev2. I reinstalled libraries and the problem continues... I don't know what's wrong. I tried some examples from Arduino and no one worked, always the same error "IMU failed"... May be it's due to hardware, but I bought it new, and all the rest services work correctly...
Hmmm. . .
that is the correct library for the
BLE Rev2 (and Sense Rev2)
I've run this on a Sense_Rev2
(I struck out the BLE stuff - don't know if it makes a diff) --
#include "Arduino_BMI270_BMM150.h"
float x, y, z;
  Serial.begin(19200);
  while (!Serial);
  Serial.println("Started");
  if (!IMU.begin())
    while (1);
  Serial.print("Accelerometer sample rate = ");
  Serial.print(IMU.accelerationSampleRate());
  Serial.println(" Hz");
  Serial.println("Acceleration in G's");
  Serial.println("X\tY\tZ");
  Serial.print(x);
  Serial.print('\t');
  Serial.print(y);
  Serial.print('\t');
  Serial.println(z);
Thanks!!, I tried your code and didn't worked "Failed to initialize IMU!". Do you know if is there a tool or a code for testing the hardware?
So far as a sketch to validate operation - you have it.
Is the IC there, on the board, in place ?
PE - There may be a Boards Manager update needed?
(Arduino Mbed OS Nano Boards)
I have a Nano33 BLE with the LSM9DS1. The IMU is on the Wire1 bus, and I can find two addresses for it with this version of the i2c scanner program. Does it find any devices on the board you have?
#include <Wire.h>
  while (!Serial);
  Wire1.begin();
  Serial.println ();
  Serial.println ("I2C Wire1 scanner. Scanning ...");
  byte count = 0;
  for (byte i = 1; i < 120; i++)
    Wire1.beginTransmission (i);
    if (Wire1.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
void loop() {}
This is the result of your code, just one device
Found address: (0x68)
Done.
Found 1 device(s).
What does it mean?. Thanks!!
Thanks, I had read the text and didn't found any reason for the error... I don't know where I caould find more info....
Did you try to see if there is an Update in Boards Manager (Post No.8) ?
Yes, I did... no updates
There should be two addresses.
Somewhere deep in the library source code you can find the exact addresses.
https://github.com/arduino-libraries/Arduino_BMI270_BMM150/tree/master
@kakauet
Just to let you know -
the sketch that I posted in No.6 ran fine with my BLE_Sense_Rev2
and it runs fine with my BLE_Rev2.
As I see it, the IMU IC on yours is likely bad.
Thanks for your help, finally, the nano board was damaged, I changed it and it works!!
