I was very interested to get an Arduino 33 BLE Head Tracker working but I bought the model that is incompatible to the project I was wanting to use.
The code is for the LSM9DS1 IMU
I didn’t realise there were 4 different models of the Nano 33 BLE with and without headers.
Nano 33 BLE rev1 with LSM9DS1
Nano 33 BLE rev2 with BMM270 & BMI150
Nano 33 BLE SENSE rev1 with LSM9DS1
Nano 33 BLE SENSE rev2 with BMM270 & BMI150
I include the main sketch below.
I have bought the Nano 33 BLE rev2 with BMM270 & BMI150 and wanted to know if there is a way to alter the code to work. My initial reason is to utilise the Bluetooth for non-corded connection.
I am open to other alternatives if you have any.
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h>
#include "SensorFusion.h"
// LED Pin definitions
// *RGB PINS ARE INVERTED ON THIS BOARD*
// for RED, BLUE, GREEN, and BUILTIN only: HIGH means LOW and vice versa.
#define PIN_LED (13u)
#define LED_BUILTIN PIN_LED
#define RED (22u)
#define GREEN (23u)
#define BLUE (24u)
#define LED_PWR (25u)
//TEST MODE ENABLE OR DISABLE
bool TestMode = false; //Set true to output data directly to serial (bypass hatire conversion + range mapping)
//Variables only required in test mode
int loopFrequency = 0;
const long displayPeriod = 100;
unsigned long previousMillis = 0;
//Init filter
SF fusion;
//Init gyro vars
float gX = 0, gY = 0, gZ = 0;
//Init accel vars
float aX = 0, aY = 0, aZ = 0;
//Init mag vars
float mX = 0, mY = 0, mZ = 0;
//Init delta time
float deltat;
//BLE variables + init
bool BLEconnected = false;
const char* deviceServiceUuid = "19b10000-e8f2-537e-4f6c-d104768a1214";
const char* deviceServiceCharacteristicUuid = "19b10001-e8f2-537e-4f6c-d104768a1214";
BLEService opentrackService(deviceServiceUuid);
BLECharacteristic hatireCharacteristic(deviceServiceCharacteristicUuid, BLERead | BLEWrite | BLENotify, 30, true);
//this structure is needed by hatire
struct {
int16_t Begin; // 2 Debut
uint16_t Cpt; // 2 Compteur trame or Code
float gyro[3]; // 12 [Y, P, R] gyro (actually just the Y,P,R from the fusion filter)
float acc[3]; // 12 [x, y, z] Acc (this is left empty and ignored)
int16_t End; // 2 Fin
} hat;
////////Converts degrees to radians////////////
float degreesToRadians(float degreeIn) {
return (degreeIn * 71) / 4068.0;
///////Converts G's to m/s^2//////////////
float gsToMss(float gIn) {
return gIn * 9.80665;
// Sends hat struct to hatire using current communication method //
void sendAnglesToHatire() {
// Send HAT Frame to PC base on communication mode
// if bluetooth mode
if (BLEconnected) {
hatireCharacteristic.writeValue((byte*)&hat,30);
// else serial mode
else {
Serial.write((byte*)&hat,30);
hat.Cpt++;
if (hat.Cpt>999)
hat.Cpt=0;
// Updates the IMU and fusion filter to get new data //
void updateAngles() {
// ------Check for new IMU data and update angles------
//update gryo if available
if (IMU.gyroAvailable()) {
IMU.readGyro(gX, gY, gZ);
//update accel if available
if (IMU.accelAvailable()) {
IMU.readAccel(aX, aY, aZ);
//update mag if available
if (IMU.magnetAvailable()) {
IMU.readMagnet(mX, mY, mZ);
//Gyro and Accel conversions
gX = degreesToRadians(gX);
gY = degreesToRadians(gY);
gZ = degreesToRadians(gZ);
aX = gsToMss(aX);
aY = gsToMss(aY);
aZ = gsToMss(aZ);
//get delta time
deltat = fusion.deltatUpdate();
//Update filter
//fusion.MahonyUpdate(gX, gY, gZ, aX, aY, aZ, deltat);
//fusion.MahonyUpdate(gX, gY, gZ, aX, aY, aZ, mX, mY, mZ, deltat);
fusion.MadgwickUpdate(gX, gY, gZ, aX, aY, aZ, mX, mY, mZ, deltat);
if (TestMode){
// Display sensor data every displayPeriod, non-blocking.
if (millis() - previousMillis >= displayPeriod) {
Serial.print("Pitch:");
Serial.print(fusion.getRoll());
Serial.print("\tRoll:");
Serial.print(fusion.getPitch());
Serial.print("\tYaw:");
Serial.println(fusion.getYaw());
Serial.print("\tLoop Frequency: ");
Serial.print(loopFrequency);
Serial.println(" Hz");
loopFrequency = 0;
previousMillis = millis();
loopFrequency++;
else {
//Assign yaw, pitch, and roll in hatire struct
hat.gyro[0]=map(fusion.getYaw(), 0, 360, -180, 180); //Yaw in opentrack
hat.gyro[1]=-fusion.getPitch(); //Roll in opentrack
hat.gyro[2]=fusion.getRoll(); //Pitch in opentrack
sendAnglesToHatire();
// Setup function, runs at boot //
// Set hatire constants //
// header frame
hat.Begin=0xAAAA;
// Frame Number or err code
hat.Cpt=0;
// footer frame
hat.End=0x5555;
// initialize the led digital pins as an output
pinMode(LED_BUILTIN, OUTPUT);
pinMode(RED, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(LED_PWR, OUTPUT);
//Disable power LED until setup procedure is complete, Enable purple while booting up
digitalWrite(LED_PWR, LOW);
digitalWrite(RED, LOW);
digitalWrite(GREEN, HIGH);
digitalWrite(BLUE, LOW);
digitalWrite(LED_BUILTIN, LOW);
//Bluetooth Init
BLE.begin();
BLE.setLocalName("Nano 33 Head Tracker");
BLE.setAdvertisedService(opentrackService);
opentrackService.addCharacteristic(hatireCharacteristic);
BLE.addService(opentrackService);
BLE.advertise();
//Serial and filter Start
//If IMU will init
if (IMU.begin()) {
Serial.print("LSM9DS1 IMU Connected.\n");
//Set boot up led RED only by disabling blue to indicate device is now running and waiting for connection
digitalWrite(BLUE, HIGH);
//----------------------------------Set calibration data--------------------------------------------
//----------------------------PASTE YOUR CALIBRATION DATA HERE--------------------------------------
// Accelerometer code
IMU.setAccelFS(0);
IMU.setAccelODR(2);
IMU.setAccelOffset(0.000000, 0.000000, 0.000000);
IMU.setAccelSlope (1.000000, 1.000000, 1.000000);
// Gyroscope code
IMU.setGyroFS(1);
IMU.setGyroODR(2);
IMU.setGyroOffset (0.000000, 0.000000, 0.000000);
IMU.setGyroSlope (1.000000, 1.000000, 1.000000);
// Magnetometer code
IMU.setMagnetFS(0);
IMU.setMagnetODR(7);
IMU.setMagnetOffset(0.000000, 0.000000, 0.000000);
IMU.setMagnetSlope (1.000000, 1.000000, 1.000000);
else {
// LSM9DS1 IMU not found
//Flash Red Light To indicate IMU error
while(1) {
digitalWrite(RED, HIGH);
// Attemps connection over BT and usb serial over and over. //
// Once connected, runs main loop until disconnected. //
//LED red, pwr LED off while disconnected
//Attempt Serial and Bluetooth connection
BLEDevice central = BLE.central();
//if connected with BT or serial, else restart loop
if (Serial || central) {
//If bluetooth mode
if (central.connected()) {
BLEconnected = true;
digitalWrite(LED_PWR, HIGH);
//call main loop, runs while connected
while(central.connected()) {
updateAngles();
// Wait for new sample - 7 ms delay provides a ~100Hz sample rate / loop frequency
delay(14);
// Else usb serial mode
else {
BLE.stopAdvertise();
while(Serial) {
updateAngles();
delay(14);
