I am working on a fall detection system using the Arduino Nano 33 BLE Sense Rev 2 board. The goal is to detect falls using data from the BMI270 sensor, send a Bluetooth signal to a mobile app, and trigger an SMS when a fall is detected. My device is not connecting to the app. I tried a basic ble connection code then it connected but when i try with my code it is not connecting.
/* Edge Impulse ingestion SDK
* Copyright (c) 2022 EdgeImpulse Inc.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Includes ---------------------------------------------------------------- */
#include <Fall_detecting_inferencing.h>
#include <Arduino_BMI270_BMM150.h> //Click here to get the library: https://www.arduino.cc/reference/en/libraries/arduino_bmi270_bmm150/
#include <ArduinoBLE.h>
/* Constant defines -------------------------------------------------------- */
#define CONVERT_G_TO_MS2 9.80665f
#define MAX_ACCEPTED_RANGE 2.0f // starting 03/2022, models are generated setting range to +-2, but this example use Arudino library which set range to +-4g. If you are using an older model, ignore this value and use 4.0f instead
** NOTE: If you run into TFLite arena allocation issue.
** This may be due to may dynamic memory fragmentation.
** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
** if it doesn't exist) and copy this file to
** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
** See
** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
** to find where Arduino installs cores on your machine.
** If the problem persists then there's not enough memory for this model and application.
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
static float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
/* Forward declaration */
void run_inference_background();
//Blutooth service activating
BLEService fall_service("e267751a-ae76-11eb-8529-0242ac130003");
BLEIntCharacteristic fall("e267751b-ae76-11eb-8529-0242ac130003", BLERead | BLENotify);
* @brief Arduino setup function
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
BLE.setLocalName("Fall_Detecter");
BLE.setAdvertisedService(fall_service);
fall_service.addCharacteristic(fall);
BLE.addService(fall_service);
BLE.advertise();
Serial.println("Bluetooth device active, waiting for connections...");
// comment out the below line to cancel the wait for USB connection (needed for native USB)
while (!Serial);
Serial.println("Edge Impulse Inferencing Demo");
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
IMU.setContinuousMode();
ei_printf("IMU initialized\r\n");
if (EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME != 3) {
ei_printf("ERR: EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME should be equal to 3 (the 3 sensor axes)\n");
return;
inference_thread.start(mbed::callback(&run_inference_background));
* @brief Return the sign of the number
* @param number
* @return int 1 if positive (or 0) -1 if negative
float ei_get_sign(float number) {
return (number >= 0.0) ? 1.0 : -1.0;
* @brief Run inferencing in the background.
// wait until we have a full buffer
delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
// This is a structure that smoothens the output result
// With the default settings 70% of readings should be the same before classifying.
ei_classifier_smooth_t smooth;
ei_classifier_smooth_init(&smooth, 10 /* no. of readings */, 7 /* min. readings the same */, 0.8 /* min. confidence */, 0.3 /* max anomaly */);
while (1) {
// copy the buffer
memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
// Turn the raw buffer in a signal which we can the classify
signal_t signal;
int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
ei_printf("Failed to create signal from buffer (%d)\n", err);
return;
// Run the classifier
ei_impulse_result_t result = { 0 };
err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run classifier (%d)\n", err);
return;
// print the predictions
ei_printf("Predictions ");
ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
result.timing.dsp, result.timing.classification, result.timing.anomaly);
ei_printf(": ");
// ei_classifier_smooth_update yields the predicted label
const char *prediction = ei_classifier_smooth_update(&smooth, &result);
ei_printf("%s ", prediction);
// print the cumulative results
ei_printf(" [ ");
for (size_t ix = 0; ix < smooth.count_size; ix++) {
ei_printf("%u", smooth.count[ix]);
if (ix != smooth.count_size + 1) {
ei_printf(", ");
else {
ei_printf(" ");
ei_printf("]\n");
// Check if the predicted label is "fall"
if (strcmp(prediction, "fall") == 0) {
Serial.println("Fall detected!");
Serial.println("No fall detected.");
delay(run_inference_every_ms);
ei_classifier_smooth_free(&smooth);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
BLEDevice central = BLE.central();
if (central) {
Serial.println("Connected to central");
while (central.connected()) {
// Send notification or any minimal action
fall.writeValue(1); // Just sending a small value
Serial.println("Disconnected from central");
BLE.advertise();
while (1) {
// Determine the next tick (and then sleep later)
uint64_t next_tick = micros() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
// roll the buffer -3 points so we can overwrite the last one
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
// read to the end of the buffer
IMU.readAcceleration(
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1]
for (int i = 0; i < 3; i++) {
if (fabs(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) > MAX_ACCEPTED_RANGE) {
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i] = ei_get_sign(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) * MAX_ACCEPTED_RANGE;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] *= CONVERT_G_TO_MS2;
// and wait for next tick
uint64_t time_to_wait = next_tick - micros();
delay((int)floor((float)time_to_wait / 1000.0f));
delayMicroseconds(time_to_wait % 1000);
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_ACCELEROMETER
#error "Invalid model for current sensor"
#endif
What am i doing wrong. Any help or suggestions would be much appreciated. Thanks in advance
