Hey all,
Im taking a whack at using the IoT cloud and wanted to setup my latest project which is basically an Arduino Nano 33 IoT with a ELEGOO 8-Channel relay board. I have been chiseling away at the code and am about to hook up the sensors and wanted to see if any of the code masters had any feedback or suggestions on the layout/code.
I am going to be using 2 DHT22 temperature and humidity sensors so that adds a little more fun I am trying to read all 4 measurements from the two sensors and convert the temp to degrees Fahrenheit . I started those up with this at the top:
#define DHTPIN1 21
#define DHTPIN2 20
DHT dht[] = {
{DHTPIN1, DHT22},
{DHTPIN2, DHT22},
Then later in the code this:
//does something for sensors???
for (auto& sensor : dht) {
sensor.begin();
Not sure if it is being initialized correctly...
Long story short.. as I progress.. I want to be able to create at least two thermostat type conditions for temp1 and temp2 (via relay1 and relay2) and also be able to control humidity for "hum1" (relay3).. Hopefully building more on there as I go...
Any suggestions or tips? Im not looking for highly sophisticated control... like PID... just ON/OFF for now... in the future it may be cool to ADD a PID style control for one of the heater relays...
Here is a reference code I used for a dual DHT22 Sensor configuration.
Sketch generated by the Arduino IoT Cloud Thing
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
int t_temp2;
int t_temp1;
int t_hum1;
float temp1;
float temp2;
float hum1;
float hum2;
bool redLED;
bool relay4;
bool relay5;
bool relay3;
bool relay6;
bool relay8;
bool relay1;
bool relay2;
bool relay7;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// DHT sensor library - Version: 1.4.3
#include <DHT.h>
#include <DHT_U.h>
//Sensor 1 and 2
#define DHTPIN1 21
#define DHTPIN2 20
DHT dht[] = {
{DHTPIN1, DHT22},
{DHTPIN2, DHT22},
float hum[2];
float temp[2];
//Fahrenheit conversion variables
float calc[2];
int myLED = 13;
int relayArray[] = {2, 3, 4, 5, 6, 7, 8, 9};
int temp1TOL= 5; // hysteresis or tolerance for temp1
int temp2TOL = 5; // hysteresis or tolerance for temp1
//Set relay array as outputs and state
for (int ir=0;ir<8;ir++) {
pinMode(relayArray[ir], OUTPUT);
digitalWrite(relayArray[ir], HIGH);
sensor.begin();
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Iot generated VARiables as defined in thingProperties.h
initProperties();
//CLOUD GENERATED: Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
delay(2000);
for (int i = 0; i < 2; i++) {
temp[i] = dht[i].readTemperature();
hum[i] = dht[i].readHumidity();
// convert the temp to deg fahrenheit
for (int ic = 0; ic < 2; ic++) {
//T(°F) = T(°C) × 9/5 + 32
calc[ic] = (temp[ic] * 1.8 ) + 32;
//condition for relay1 on
if (calc1 >= t_temp1 + temp1TOL){
relay1 = 0;
}else if(calc1 >= t_temp1){
relay1 = 0;
}else{
relay1 = 1;
//condition for relay2 on
if (calc2 >= t_temp2 + temp2TOL){
relay2 = 0;
}else if(calc2 >= t_temp2){
relay2 = 0;
}else{
relay2 = 1;
Serial.print("Temp1 Setpoint = ");
Serial.print(t_temp1);
//Print degree symbol
Serial.write(176);
Serial.println("F");
Serial.print("Temp1 = ");
Serial.print(calc[0]);
Serial.write(176);
Serial.print("Temp2 Setpoint = ");
Serial.print(t_temp2);
Serial.write(176);
Serial.print("Temp2 = ");
Serial.print(calc[1]);
Serial.write(176);
Since Port1 is READ_WRITE variable, onPort1Change() is
executed every time a new value is received from IoT Cloud.
void onPort1Change() {
// Add your code here to act upon Port1 change
Since RedLED is READ_WRITE variable, onRedLEDChange() is
void onRedLEDChange() {
// Add your code here to act upon RedLED change
Serial.println(redLED);
if(redLED){
digitalWrite(myLED,HIGH);
}else{
digitalWrite(myLED,LOW);
Since Relay1 is READ_WRITE variable, onRelay1Change() is
void onRelay1Change() {
// Add your code here to act upon Relay1 change
if(relay1){
digitalWrite(relayArray[0],HIGH);
}else{
digitalWrite(relayArray[0],LOW);
Since Relay2 is READ_WRITE variable, onRelay2Change() is
void onRelay2Change() {
// Add your code here to act upon Relay2 change
if(relay2){
digitalWrite(relayArray[1],HIGH);
}else{
digitalWrite(relayArray[1],LOW);
Since Relay3 is READ_WRITE variable, onRelay3Change() is
void onRelay3Change() {
// Add your code here to act upon Relay3 change
if(relay3){
digitalWrite(relayArray[2],HIGH);
}else{
digitalWrite(relayArray[2],LOW);
Since Relay4 is READ_WRITE variable, onRelay4Change() is
void onRelay4Change() {
// Add your code here to act upon Relay4 change
if(relay4){
digitalWrite(relayArray[3],HIGH);
}else{
digitalWrite(relayArray[3],LOW);
Since Relay5 is READ_WRITE variable, onRelay5Change() is
void onRelay5Change() {
// Add your code here to act upon Relay5 change
if(relay5){
digitalWrite(relayArray[4],HIGH);
}else{
digitalWrite(relayArray[4],LOW);
Since Relay6 is READ_WRITE variable, onRelay6Change() is
void onRelay6Change() {
// Add your code here to act upon Relay6X change
if(relay6){
digitalWrite(relayArray[5],HIGH);
}else{
digitalWrite(relayArray[5],LOW);
Since Relay7 is READ_WRITE variable, onRelay7Change() is
void onRelay7Change() {
// Add your code here to act upon Relay7 change
if(relay7){
digitalWrite(relayArray[6],HIGH);
}else{
digitalWrite(relayArray[6],LOW);
Since Relay8 is READ_WRITE variable, onRelay8Change() is
void onRelay8Change() {
// Add your code here to act upon Relay8 change
if(relay8){
digitalWrite(relayArray[7],HIGH);
}else{
digitalWrite(relayArray[7],LOW);
void onTTemp2Change() {
void onTTemp1Change() {
void onTHumChange() {
