Nano BLE rev2 BMI270 BMM150 reading issue w scheduler
I've bought a Nano BLE rev 2 to test it after using the rev 1 successfully.
With Nano rev 1 and LSMDS1 sensor my code with magdwick filter, BT and scheduler runs perfectly but with rev 2 and BMI270 BMM150 new sensors, the sensor's values are all 0.
So I tried to simulate my code with following example modified with two loops and the scheduler. The first loop with about the time necessary for the loop 1 of original code and the behaviour is very similar.
Setting opportunely the library to include, the Nano rev 1 runs correctly instead the rev 2 not.
Please, someone can tell me where I wrong?
Both IDE 1.8.19 / 2.3.2and last library revision available, and Arduino Emb OS edge 4.1.1.
#include <Scheduler.h>
//#include <Arduino_LSM9DS1.h>                                    // use for Nano BLE rev1
#include <Arduino_BMI270_BMM150.h>                              // use for Nano BLE rev2
  while (!Serial);
  Serial.println("Started");
  if (!IMU.begin()) {
    Serial.println("Failed to initialize IMU!");          // Check for Nano BLE revision
    while (1);
  Scheduler.startLoop(loop2);
// START LOOP1 OF PROGRAM
delay(300);                                                // to simulate other code running slowly
yield();                                                   // close loop to move to other
// END LOOP1 OF PROGRAM
// START LOOP2 OF PROGRAM
void loop2()
  float x, y, z;
  if (IMU.accelerationAvailable()) {
    IMU.readAcceleration(x, y, z);
    Serial.print(x);
    Serial.print('\t');
    Serial.print(y);
    Serial.print('\t');
    Serial.println(z);
}// END LOOP2 OF PROGRAM
Anyway after several days of test, I had modified my code inserting the IMU readings in the main Loop and run correctly, I think is very probable that the reading time for the BMI270 in the Nano BLE rev 2 is bigger than the LSM9DS1 of Nano BLE rev. 1. So at the end of the day, pay attention in your project that Nano BLE rev 1 and Rev2 are not fully compatible.
