bc238c
June 9, 2026, 10:58am
1
Hi, just for the record: It took me quite a while to solve the problem of Arduino NANO clones with the CH340 serial interface chip. The following solution worked for me:
WIN 10
ARDUINO IDE 1.8.19
Installed driver: 3.7.2022.1
DO NOT USE a more modern driver as at least the driver 3.9.2024.9 from WCN is buggy.
AVRDude Ver. 6.3-arduino17
Also it could be possible AVRDude 8.0-arduino.1 cannot handle the proper timing of the CH340 properly. Can anybody confirm this?
I do not have a problem with that driver. Does your CH340 have a marking on it?
Result of upload using IDE 1.8.19, IDE 2.x also works without problems.
Sketch uses 1960 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 194 bytes (9%) of dynamic memory, leaving 1854 bytes for local variables. Maximum is 2048 bytes.
C:\Users\bugge\ArduinoIDE\1_arduino-1.8.19.generic\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\bugge\ArduinoIDE\1_arduino-1.8.19.generic\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM19 -b57600 -D -Uflash:w:C:\Users\bugge\AppData\Local\Temp\arduino_build_953838/exportTest_01.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\bugge\ArduinoIDE\1_arduino-1.8.19.generic\portable\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM19
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\bugge\AppData\Local\Temp\arduino_build_953838/exportTest_01.ino.hex"
avrdude: writing flash (1960 bytes):
Writing | ################################################## | 100% 0.59s
avrdude: 1960 bytes of flash written
avrdude: verifying flash memory against C:\Users\bugge\AppData\Local\Temp\arduino_build_953838/exportTest_01.ino.hex:
avrdude: load data flash data from input file C:\Users\bugge\AppData\Local\Temp\arduino_build_953838/exportTest_01.ino.hex:
avrdude: input file C:\Users\bugge\AppData\Local\Temp\arduino_build_953838/exportTest_01.ino.hex contains 1960 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.45s
avrdude: verifying ...
avrdude: 1960 bytes of flash verified
avrdude done. Thank you.
sterretje:
IDE 1.8.19, IDE 2.x
I just built a new Linux system, Mint 22.2 and the IDE loaded and operated 'out of the box' No tweaks, just plugged it in and it works.
