Hi
I'm trying to connect MIDI output from the Nano over Bluetooth LE to a PC running a DAW (Ableton Live) using the BLE-MIDI library. I'm using the MIDIberry program on the Windows 10 machine to check the status. I can connect fine to the BLE instance but the input never shows anything for some reason. The program I am using is
#include <BLEMIDI_Transport.h>
//#include <hardware/BLEMIDI_ESP32_NimBLE.h>
//#include <hardware/BLEMIDI_ESP32.h>
//#include <hardware/BLEMIDI_nRF52.h>
include <hardware/BLEMIDI_ArduinoBLE.h>
BLEMIDI_CREATE_DEFAULT_INSTANCE()
unsigned long t0 = millis();
bool isConnected = false;
// When BLE connected, LED will turn on (indication that connection was successful)
// When receiving a NoteOn, LED will go out, on NoteOff, light comes back on.
// This is an easy and conveniant way to show that the connection is alive and working.
MIDI.begin();
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
BLEMIDI.setHandleConnected([]() {
isConnected = true;
digitalWrite(LED_BUILTIN, HIGH);
BLEMIDI.setHandleDisconnected([]() {
MIDI.setHandleNoteOn([](byte channel, byte note, byte velocity) {
MIDI.setHandleNoteOff([](byte channel, byte note, byte velocity) {
MIDI.read();
if (isConnected && (millis() - t0) > 1000)
t0 = millis();
MIDI.sendNoteOn (60, 100, 1); // note 60, velocity 100 on channel 1
If I put a Serial.println("Info sent") after the MIDI.sendnote, it is printed so the line is being executed. Does anyone have any ideas why the input shows nothing?
Bipman
