Nano iot33 serial port example troubles, resolved
I am trying to get serial data thru TX/RX on nano 33 iot. but not receiving anything
so, I decided to verify using the example
and get the same results.. the sender responds to entered data on usb serial port
the receiver never responds.
I added verification in the receiver loop that it is running
but Serial1.available()>=0 never becomes true
the sender
  pinMode(LED_BUILTIN, OUTPUT);      // set LED pin as output
  digitalWrite(LED_BUILTIN, LOW);    // switch off LED pin
 while(!Serial)
 while(!Serial1)// initialize serial communication at 9600 bits per second:
  Serial1.begin(9600);
  //Serial1.println("test");// initialize UART with baud rate of 9600
  if (Serial.read() == '1'){
    Serial1.println('1');
    Serial.println("loop");
    digitalWrite(LED_BUILTIN, HIGH);
    Serial.println("LEDS ON");
  else if (Serial.read() == '0'){
    Serial1.println('0');
    Serial.println("loop1");
    Serial.println("LEDS OFF");
the receiver
 while(Serial)
while(!Serial1)
Serial1.begin(9600);            // initialize UART with baud rate of 9600
  while (Serial1.available() >= 0) {
    char receivedData = Serial1.read();   // read one byte from serial buffer and save to receivedData
    if (receivedData == '1') {
      digitalWrite(LED_BUILTIN, HIGH); // switch LED On
    else if (receivedData == '0') {
      digitalWrite(LED_BUILTIN, LOW);  // switch LED Off
Please provide details. I don't see anything added to the "receiver" sketch that could be considered "verification".
I do see this code you added though:
This code will cause the sketch to hang in a perpetual loop, calling Serial.begin(9600); over and over and over again until you connect the "receiver" board to your computer via its USB cable and open that board's serial port in the Arduino IDE Serial Monitor (or any equivalent application).
The tutorial is written with the intent that you only have the "sender" board connected to your computer with the Serial Monitor.
Since you aren't even doing anything with Serial in the "receiver" sketch, this seems like a very bad addition all around.
I also see this addition:
This would cause Serial1.begin(9600); to be called over and over again as long as Serial1 is false. That a strange thing on its own, since you only need to call Serial1.begin(9600); once, but you'll see it is downright disastrous once you study the documentation:
On the boards with native USB, if (Serial) (or if(SerialUSB) on the Due) indicates whether or not the USB CDC serial connection is open. For all other boards, and the non-USB CDC ports, this will always return true.
Serial1 is a "non-USB CDC port", so this means the while condition will never evaluate as true, and thus Serial1 is never initialized.
I strongly recommend starting out by following the tutorial exactly. Once you have the "known good" code working as expected, you can feel free to methodically iterate on that to add whatever additional functionality you want. But jumping right in with random modifications from the start is not a recipe for success.
I didn't do 'random' mods.
I did the code as written, copy paste.
the receiver lights don't follow the sender.
so, altho the code isn't there now, I added a Serial.println() to loop, to insure it was running
I added a serial.println() to the end of setup to insure it finished
I added Serial.println to show that data was received from the Serial.available and read
the example says you don't NEED to have the receiver connected, but I do.
I added the whiles, just because my other sketches do.
The code you shared here is definitely not a copy/paste of the code in the tutorial.
Please try it again without the random modifications.
yep, why it works now, same cut and paste as original attempt.. i do not know
adding the serial.xxx functions also works
thanks..
now to find out why the other sketch doesn't do the same
in 'random' modifications
  • missing ; after while
  • missing ! in while (Serial)
  • testing serial connection state before begining it
so the original sketch issue
receive data over tx/rx, 115200, n81
setup
  Serial1.begin(115200);
  while (!Serial){
loop
  while (Serial1.available() >= 0){
    Serial.println("incoming data");
// write a message to serial to acknowledge data received
    Serial.write(Serial1.read());
other stuff (BLE) which works)
get stuck in the while loop
08:54:54.436 -> ⸮incoming data
08:54:54.539 -> ⸮incoming data
but there isn't any incoming data yet
with rx/tx disconnected get the same
i put the sample at 115200 for tx/rx and all ok
so, is serial1 not available when using BLE? on nano iot
i think there are two different chips Nina for wifi/ble
from the datasheet page 8
Communication with NINA W102 happens through a serial port and a SPI bus through the following pins
31 PA22 23 GPIO3 Processor TX Nina RX
32 PA23 22 GPIO1 Processor RX Nina TX
using the sample receiver at 115200 from my other board works as expected.
does not work when BLE is used
yes, Serial1 is connected not only to RX/TX pins, but to the Nina module and ArduinoB:E library uses it for communication with the nina-fw n the Nina
bummer..
my external board can only send thru UART
now I need USB host mode on the NANO to connect BOTH boards, argh!
actually its Serial2 for nina.
and Serial1 problem resolved
doah!
while (Serial1.available() > 0){
sorry. MKR 1010 has it on Serial1. they made it better for Nano Iot
