I try to implement a function triggered by a PIO IRQ ( pio_IRQhandler() ), but when I include the IRQ handeling code into sketch, the rp2040 crashes after call (GPIO 20 High). I searched for doc, but couldn't find any official documents, only this into forum posts ... reason why.
Sketch Code that generate crash:
// Enable IRQ0 & 1 on PIO0
irq_set_exclusive_handler(PIO0_IRQ_0, pio_IRQhandler); // IRQ7 = PIO0_IRQ_0
irq_set_enabled(PIO0_IRQ_0, true);
pio0_hw->inte0 = PIO_IRQ0_INTE_SM0_BITS | PIO_IRQ0_INTE_SM1_BITS;
If the code above is not present, i runs fine. What is the correct code to use then? Or How to fix this issue? ... any clue is welcome
for reference, PIO Code:
mainloop:
pull noblock ; Loads OSR with delay value
mov x,osr ; OSR contents to X to prepare for future noblock pulls
mov y,x ; Load (Number of Loops - 1) value into Y => "lloping"
;irq clear 0
wait 1 gpio 20 ; Wait for GPIO 20 Trigger (High=1)
looping: ; Start "looping" loop
set pins, 1 [31] ; Turn Led ON ( GPIO 25)
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
set pins, 0 [31] ; Turn Led OFF
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
nop [31]
jmp y-- looping [31] ; Jumps to "looping" if y not 0, then decrements y
irq set 0 ; Set IRQ 0 active to triffer function pio_IRQhandler() in sketch
jmp mainloop
Sketch:
// PIO IRQs handling
void pio_IRQhandler() {
irq_clear(PIO0_IRQ_0);
Serial.print("PIO0 IRQ0 !!!\n" );
Thank you in advance for your help or sharing of experiences around this,
Henry
