I have a board that's main function will be to run several motor controllers. On the board, there are all the components from the Arduino Nano 3.2 schematics available online. I am using an ATmega328P. The master Nano is either a 3.2 or 3.3, I don't remember- but I am trying to find the box.
Regardless, I am waiting to put the other components onto the PCB until I confirm that the arduino part of the board works as expected. I connected the USB port, and attempted to download code. From reading other forum posts, I figured out that I needed to make sure it had the bootloader.
I then completed the following steps:
- Connected the 5v, gnd, D11, D12, and D13 pins from the master board to the same pin on the slave board.
- Connected D10 from the master board to rst on the slave board.
- Downloaded the ArduinoISP program onto the master board with the correct COM port, board, and processor (with the programmer set to "Arduino as ISP"). This completed successfully.
- Clicked "Burn Bootloader"
That is when I get these errors:
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x66
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x64
avrdude done. Thank you.
Error while burning bootloader.
I don't have any LEDs on the master Nano yet, as I am trying to source some resistors. I will try to get the LED output of the ISP soon.
Other things I have tried:
- Loopback Test: successful
- Commented and uncommented "#define USE_OLD_STYLE_WIRING" (Neither worked)
- Swapped the 328P on the board for the other one I bought
- Restarting everything/trying different cables
- Triple checked all soldered components
- Ran the avrdude command with '-F' (unsuccessful as well)
Any help would be greatly appreciated!
Can you post your schematic please.
Both of the boards follow the official schematics located here:
http://https://www.arduino.cc/en/uploads/Main/Arduino_Nano-Rev3.2-SCH.pdf
These are the connections between the boards:
I've found that this process works for me only if I have a 10uF capacitor to ground on the programmer Nano's reset pin. I'm running v1.8.8 of the IDE. I've been told repeatedly that I shouldn't need this capacitor when using any of the newer IDE versions, but nevertheless I do need it for the flashing to work, including when using AVRdude. You might just give it a try.
I added the capacitor, ran the same steps, and nothing changed.
I also doubled checked what version of the IDE I'm on, and I'm on 1.8.13.
I don't know if this is relevant, but I downloaded the IDE again and my error message is essentially the same, but slightly different.
Here it is:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x00ffff
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Your latest error is exactly what I get if I don't connect the slave to the master and press "burn bootloader". When connecting 2 Nano's together as per your schematic it works just fine. So I suspect your board. Maybe try with a naked atmega328p or another nano first as slave?
I tried using two completely new nanos to have them burn the bootloader on eachother. Neither configuration worked with the slave or with the master. Here is the error I am getting when trying to burn the bootloader:
Using Port : COM12
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
this check.
The reason for the error directly above was because I still had the #DEFINE for the old wiring style. I updated that, and both arduinos could burn to eachother. When I tried this configuration with the other PCB, I get a different error, which is this one:
Using Port : COM12
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
avrdude: Yikes! Invalid device signature.
this check.
Why would the device have the wrong signature?
I think that error message can also result from a wiring problem. If you know that the programmer Nano is working correctly, then it seems something must be wrong with your target's board. Perhaps something else is also connected to the SPI pins that's messing things up. Or I guess something could be wrong with the chip, but that's really unlikely
That is not the device signature, but a more or less random value, that you will get if the connection is not good. I start to wonder if you added passive or active components on your board that connect to the same pins D11, D12 and D13 while you try to burn the bootloader. If so, I would desolder those components, so that no other active or passive components can interfere with the Nano <> Nano connection.
You may want to post the schematic of you board here,
Oops, forgot to respond.
I got it working- you were all on the correct track.
The issue here was that there were other passive components attached to the programming pins.
Thank you everyone for your help.
