Well the code is waiting on mySerial.available(), I thought that had nothing to do with the USB connection Serial().
Anyway here’s all the code. The Nano Code:
#include <SoftwareSerial.h>
// Relay pins A1 to A4
int relayPON = A1;
int relayPOFF = A2;
int relayLATCH = A3;
int relay12V = A4;
// Set up a new SoftwareSerial object
SoftwareSerial mySerial = SoftwareSerial(2, 3); // pin 2 is RX, 3 is TX, communication to Pro Micros
String msg = ""; // Initialize an empty string for messages
bool msgGood = false; // Initialize bool value for if message is good
//Assign starting LED states
char statesSw1 = 'J';
char statesSw2 = 'J';
//continue for more switches
int swNum = 0;
// ------------------RS232 commands---------------//
byte necPOFF[6] = {0x02, 0x01, 0x00, 0x00, 0x00, 0x03}; // NEC projector power off
byte necPON[6] = {0x02, 0x00, 0x00, 0x00, 0x00, 0x02}; // NEC projector power on
byte necHDBT[8] = {0x02, 0x03, 0x00, 0x00, 0x02, 0x01, 0xBF, 0xC7}; // NEC projector select HDBT input (Last value is checksum)
// Set the baud rate for the SoftwareSerial object
mySerial.begin(9600);
Serial.begin(9600); // debug with local serial monitor
// output pins for relays
pinMode(relayPON, OUTPUT);
pinMode(relayPOFF, OUTPUT);
pinMode(relayLATCH, OUTPUT);
pinMode(relay12V, OUTPUT);
//=================== START GET MESSAGE ======================//
char rc;
// the start marker is W, end marker is \n
while (mySerial.available() > 0 && mySerial.available() < 7) {
rc = mySerial.read();
if (rc != '\n') { // message has started but not reached the end
msg += rc;
delay(2);
} else { // endMarker reached
msg += '\n';
if (msg.charAt(0) == 'W' && msg.length() == 6) { // verify message
msgGood = true; // not sure if really needed or there is a simpler method, but it worked so it stays for now.
// Serial.print("Message: "); //use for debug test, can interfere with serial receiving devices parsing commands
// Serial.print(msg); //use for debug test
} // end verify message
} // end else for when rc reaches end marker (\n)
} // end while mySerial.available
//=================== END GET MESSAGE ======================//
//=================== START EVALUATE COMMANDS ======================//
if(msgGood == true){
swNum = msg.charAt(3);
//Code section for each switch.
// Manually lookup switch state on external document and construct as below
if(swNum == 49){ // 1 sent from Pro Micro is decimal 49
if(statesSw1 == 'J'){
statesSw1 = 'N';
// do switch 1 state 2 stuff (For state 2 action, typically "On" stuff)
mySerial.write("NS1"); // send message to PMs
mySerial.write("1");
mySerial.write(statesSw1);
mySerial.write("\n");
delay(50);
// relayOn();
Serial.write(necPON, 6); // power on
delay(10);
delay(20000); // projector took about 20 seconds to be ready to accept source select commands. Pro Micro blink routine "N" happens during delay.
Serial.write(necHDBT, 8); // select HDBT Input
} // end if statesSw1 == 'J'
else if(statesSw1 == 'N'){
statesSw1 = 'J';
// do switch 1 state 1 stuff (For 2 state action, typically "Off" stuff)
delay(50);
// relayOff();
Serial.write(necPOFF, 6); // power off
delay(10);
delay(20000); // projector took about 20 seconds to be ready to reset and be ready for power on
} // end if statesSw1 == 'N'
} // end if swNum == 49 (switch 1)
if(swNum == 50){ // 2 sent from Pro Micro is decimal 50
if(statesSw2 == 'J'){
statesSw2 = 'G';
// do switch 2 state 2 stuff (For 2 state action, typically "On" stuff)
relayOn();
mySerial.write("2");
mySerial.write(statesSw2);
delay(20000);
} // end if statesSw2 == 'J'
else if(statesSw2 == 'G'){
statesSw2 = 'J';
// do switch 2 state 1 stuff (For 2 state action, typically "Off" stuff)
relayOff();
delay(20000);
} //end if statesSw2 == 'G'
} // end if swNum == 50 (switch 1)
//----Expand for more switched, if swNum == 51, etc. -------//
// reset message and msgGood, empty serial buffer
msg = "";
msgGood = false;
while (mySerial.available()) { mySerial.read();}
} // end if msgGood == true
//=================== END EVALUATE COMMANDS ======================//
} // END main program
void relayOn() {
digitalWrite(relayLATCH, HIGH);
digitalWrite(relay12V, HIGH);
digitalWrite(relayPON, HIGH);
delay(600);
digitalWrite(relayPON, LOW);
void relayOff() {
digitalWrite(relayLATCH, LOW);
digitalWrite(relay12V, LOW);
digitalWrite(relayPOFF, HIGH);
delay(600);
digitalWrite(relayPOFF, LOW);
Pro Micro Code:
// Pro Micro code
int Btn1 = 2;
int Btn2 = 3;
int Btn3 = 4;
int Btn4 = 5;
int LEDG1 = 6;
int LEDR1 = 7;
int LEDG2 = 8;
int LEDR2 = 9;
int LEDG3 = 18;
int LEDR3 = 19;
int LEDG4 = 20;
int LEDR4 = 21;
int SuppRX = 14; //Socket pin 15
int SuppTX = 16; // socket pin 14
int IDPin = 10; // socket pin 13
// digitalWrite(13, HIGH); //test
pinMode(Btn1, INPUT_PULLUP);
pinMode(Btn2, INPUT_PULLUP);
pinMode(Btn3, INPUT_PULLUP);
pinMode(Btn4, INPUT_PULLUP);
pinMode(SuppRX, INPUT); // need external pulll down resistor, other Pro Micro SuppTx pin drives this pin HIGH when it sends Serial data first.
pinMode(IDPin, INPUT_PULLUP); // Pro Micro is #2 when Jumper is in place to drive this pin LOW
pinMode(LEDG1, OUTPUT);
pinMode(LEDR1, OUTPUT);
pinMode(LEDG2, OUTPUT);
pinMode(LEDR2, OUTPUT);
pinMode(LEDG3, OUTPUT);
pinMode(LEDR3, OUTPUT);
pinMode(LEDG4, OUTPUT);
pinMode(LEDR4, OUTPUT);
pinMode(SuppTX, OUTPUT);
// output pins use reverse logic, LOW turns on the LED
digitalWrite(LEDG1, HIGH);
digitalWrite(LEDR1, HIGH);
digitalWrite(LEDG2, HIGH);
digitalWrite(LEDR2, HIGH);
digitalWrite(LEDG3, HIGH);
digitalWrite(LEDR3, HIGH);
digitalWrite(LEDG4, HIGH);
digitalWrite(LEDR4, HIGH);
Serial1.begin(9600); // Serial port to Nano.
Serial.begin(9600); // if we want to print out to serial monitor for debug.
// reboot LED display
digitalWrite(LEDR1, LOW);
digitalWrite(LEDG1, LOW);
// =========== START GET MESSAGE ========================= //
char rc;
// the start marker is N, end marker is \n
while (Serial1.available() > 0 && Serial1.available() < 7) {
rc = Serial1.read();
msg += rc;
delay(2);
msg += '\n';
if (msg.charAt(0) == 'N' && msg.length() == 6) { // message verify
// Serial.print("Message: "); //test
// Serial.print(msg); //test
} // end while Serial1.available
// =========== end GET MESSAGE ========================= //
// =========== START SWITCH PRESS DETECTION ========================= //
if (digitalRead(Btn1) == LOW) { // Inputs LOW ACTIVE mode
delay(10); // software debounce
if(digitalRead(SuppRX) == LOW){
digitalWrite(SuppTX, HIGH);
if(digitalRead(IDPin) == HIGH) {Serial1.write("W1S1P\n");
Serial.println("I sent a message"); //test
} // tell Nano Pro Micro 1 button 1 was pressed
if(digitalRead(IDPin) == LOW){Serial1.write("W2S1P\n"); } // tell Nano Pro Micro 2 button 1 was pressed
delay(300);
digitalWrite(SuppTX, LOW);
} //end if suppRx is low
} // end if digitalRead(Btn1) == LOW
if (digitalRead(Btn2) == LOW) { // Inputs LOW ACTIVE mode
if(digitalRead(IDPin) == HIGH) {Serial1.write("W1S2P\n");
} // tell Nano Pro Micro 1 button 2 was pressed
if(digitalRead(IDPin) == LOW){Serial1.write("W2S2P\n"); } // tell Nano Pro Micro 2 button 1 was pressed
delay(300);
} // end if digitalRead(Btn2) == LOW
// =========== END SWITCH PRESS DETECTION ========================= //
// =========== START EVALUATE COMMANDS ========================= //
if (msg == "NS11N\n") {
msg = "";
while(Serial1.available()){Serial.read();}
Serial.println("NS11N received"); //test
for (int i = 0; i < 21; i++){
if (msg == "NS11J\n") {
msg = "";
Serial.println("NS11J received"); //test
for (int j = 0; j < 21; j++){
if (msg == "NS12G\n") {
msg = "";
Serial.println("NS12G received"); //test
for (int k = 0; k <21; k++){
digitalWrite(LEDG2, LOW);
if (msg == "NS12J\n") {
msg = "";
Serial.println("NS12J received"); //test
for (int l = 0; l < 21; l++){
digitalWrite(LEDR2, LOW);
// =========== END EVALUATE COMMANDS ========================= //
} // end main program
