Česky:
Na fóru neexistuje česká kategorie, takže je nutné psát anglicky. Pokud zveřejníte příspěvek v jedné z obecných kategorií, musíte použít angličtinu. Pokud máte projekt, který chcete financovat, je nejlepší ho vložit do příslušné kategorie. ➜ Přesunul jsem to tam.
English:
There is no Czech category on the forum, so you need to post in English. If you post in one of the general categories, you must use English. If you have a project you want to fund, it is best to post it in the appropriate category. ➜ I moved it there
Physical size? This is a bigger project if it's ... well, BIGGER. Driving enough LEDs for a meaningful 30cm diameter paddle is a different problem than a 5cm model, and may not even have meaningful battery life at reasonable brightness...
In addition to "development budget", it would be good to have a target device cost...
