Hello. Im trying to figure out what is wrong with the below code. Spend the last hour looking and no luck.
#include <TimerOne.h>
#include <Bounce2.h>
#include <Keyboard.h>
//I have used pin 10 on my board for my switch
const int inputPin = 10;
Bounce button0 = Bounce();
Bounce button1 = Bounce();
Bounce button2 = Bounce();
Bounce button3 = Bounce();
Bounce button4 = Bounce();
Bounce button5 = Bounce();
Bounce button[6] = {
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce()
//debounce milliseconds
const int debounce = 5;
//Switch Pins
const byte k[4] = { 4, 5, 6, 7 };
//Switch status
boolean s[4] = { 0, 0, 0, 0 };
byte col = 0;
byte leds[2][2];
const int keyfade = 40;
const char curve[] =
0, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 3, 3, 3, 3, 4, 4, 4, 5, 5, 6, 6, 7, 7, 7, 8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 8, 8, 7, 7, 6, 6, 5, 5, 4, 4, 3, 3, 2, 2, 1, 1, 1
const int fadecount = 2;
const unsigned long breathcount = 5000;
int fadecounter = 0;
unsigned long breathcounter = 0;
byte pass = 1;
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[6] =
-1, 18, 19, 20, 21
// col[xx] of leds = pin yy on led matrix
int cols[2] =
pins[2], pins[1]
// row[xx] of leds = pin yy on led matrix
int rows[2] =
pins[4], pins[3]
setupLeds();
onLeds();
//setup inputs, turn on pullups
for (int i = 0; i < 4; i++)
pinMode(k[i], INPUT);
digitalWrite(k[i], 1);
// Sets up the input pin for your single switch
button0.attach(inputPin);
for (int i = 4; i <= 9; i++) {
pinMode(13 - i, INPUT_PULLUP);
digitalWrite(13 - i, HIGH);
button[i - 4].attach(13 - i);
//starts the keyboard emulator
Keyboard.begin();
CheckKeys();
delay(debounce);
fadecounter++;
if (fadecounter > fadecount)
fadecounter = 0;
fade();
breathcounter++;
if (breathcounter > breathcount)
breathcounter = 0;
fadecounter = 0;
breath();
button[2].update();
if (button[2].fallingEdge()) {
//Locks computer
Keyboard.press(KEY_LEFT_GUI);
Keyboard.press('l');
Keyboard.releaseAll();
button[3].update();
if (button[3].fallingEdge()) {
//CSC main pass
Keyboard.print("gganev2");
delay (500);
Keyboard.press(KEY_TAB);
Keyboard.print("Far.cot-18");
delay (500);
Keyboard.press(KEY_RETURN);
button[4].update();
if (button[4].fallingEdge()) {
//Unlock
button[5].update();
if (button[5].fallingEdge()) {
//HPIM Incident
Keyboard.print("I will check this one.");
void CheckKeys()
if (digitalRead(k[i]) == 0)
if (s[i] == 0)
s[i] = 1;
byte row = i / 2;
byte col = i % 2;
leds[col][row] = 60;
breathcounter = 0;
if (s[i] == 1)
s[i] = 0;
byte row = i / 2;
byte col = i % 2;
breathcounter = 0;
void setupLeds()
// sets the pins as output
for (int i = 1; i <= 4; i++)
pinMode(pins[i], OUTPUT);
// set up cols and rows
for (int i = 1; i <= 2; i++)
digitalWrite(cols[i - 1], HIGH);
digitalWrite(rows[i - 1], LOW);
clearLeds();
// Set refresh rate (interrupt timeout period)
Timer1.initialize(500);
// Set interrupt routine to be called
Timer1.attachInterrupt(display);
void clearLeds()
// Clear display array
for (int i = 0; i < 2; i++)
for (int j = 0; j < 2; j++)
leds[i][j] = 0;
void onLeds()
leds[i][j] = keyfade;
void fade()
if (leds[i][j] > 0)
leds[i][j] = leds[i][j] - 1;
void breath()
leds[i][j] = 60;
// Interrupt routine
void display()
digitalWrite(cols[col], HIGH); // Turn whole previous column off
col++;
if (col == 2)
col = 0;
pass++;
if (pass > 8)
pass = 1;
for (int row = 0; row < 2; row++)
if (curve[leds[col][row]] > pass)
digitalWrite(rows[row], HIGH); // Turn on this led
digitalWrite(rows[row], LOW); // Turn off this led
digitalWrite(cols[col], LOW); // Turn whole column on at once (for equal lighting times)
Error states that: setupLeds' was not declared in this scope
Thank you in advance for the help
