I think this is the processing code I used to experiment with my accelerometer, several years ago. I don't recall, and I don't currently have access to a computer with processing installed on it.
I had to download something called gwoptics to make it work, Dr Google might be able to help you there.
import org.gwoptics.graphics.graph3D.*;
import org.gwoptics.graphics.colourmap.*;
import org.gwoptics.graphics.graph2D.backgrounds.*;
import org.gwoptics.graphics.graph2D.traces.*;
import org.gwoptics.graphics.camera.*;
import org.gwoptics.graphics.graph2D.effects.*;
import org.gwoptics.graphics.graph2D.*;
import org.gwoptics.*;
import org.gwoptics.gaussbeams.*;
import org.gwoptics.graphicsutils.*;
import org.gwoptics.mathutils.*;
import org.gwoptics.graphics.*;
import org.gwoptics.graphics.colourmap.presets.*;
import org.gwoptics.graphics.graph2D.Graph2D;
import org.gwoptics.graphics.graph2D.traces.ILine2DEquation;
import org.gwoptics.graphics.graph2D.traces.RollingLine2DTrace;
import processing.serial.*;
* Simple Read
* Read data from the serial port and change the color of a rectangle
* when a switch connected to a Wiring or Arduino board is pressed and released.
* This example works with the Wiring / Arduino program that follows below.
// The values are extracted from the serial stream from the accelerometer,
// put into these three variables, picked up by the next three eq classes
// and then put into the graph.
int accx ; // current x acceleration
int accy ;
int accz ;
// defines three classes which represent each one of the chart traces
// these classes may not be necessary but it follows the example based
class eq implements ILine2DEquation{
public double computePoint(double x,int pos) {
return accx ;
class eq2 implements ILine2DEquation{
return accy ;
class eq3 implements ILine2DEquation{
return accz ;
Serial myPort; // Create object from Serial class
int val; // Data received from the serial port
char[] buf = new char[55] ;
char ch ;
int ipos ;
RollingLine2DTrace r,r2,r3;
Graph2D g;
byte[] inbuf ;
PrintWriter ofile ;
ofile = createWriter( "acc_out.txt" );
inbuf = new byte[12] ; // a buffer to read the serial data, after the header.
size(800,400); // size of the whole window
println("Starting setup()...");
// I know that the first port in the serial list on my mac
// is always my FTDI adaptor, so I open Serial.list()[0].
// On Windows machines, this generally opens COM1.
// Open whatever port is the one you're using.
String[] portNames = Serial.list();
int len = portNames.length ;
println("portNames has "+len+" elements");
for (int i=0 ; i<len ; i++ )
println(portNames[i]);
String portName4 = new String( portNames[1]) ; // usual needs to be portNames[1] for arduino
myPort = new Serial(this, portName4, 115200 );
myPort.clear() ;
ipos=0 ;
// this is the part which sets up the graphing window
// this should create three objects for x,y,z but the x and y seem to be the wrong way around
// or maybe just the wrong colour.
r = new RollingLine2DTrace(new eq() ,3,0.003f);
r.setTraceColour(255, 0, 0); // red
r2 = new RollingLine2DTrace(new eq2(),3,0.003f);
r2.setTraceColour(0, 255, 0); // green
r3 = new RollingLine2DTrace(new eq3(),3,0.003f);
r3.setTraceColour(0, 0, 255); // blue
g = new Graph2D(this, 200, 200, false); // size of the graph section
g.setYAxisMax(1040);
g.addTrace(r);
g.addTrace(r2);
g.addTrace(r3);
g.position.y = 50; // position of the graph within the window
g.position.x = 100;
g.setYAxisTickSpacing(100);
g.setXAxisMax(6f);
long miltime ;
int xin ;
int yin ;
int zin ;
boolean gotdata ;
void draw()
accx=xin ;
accy=yin ;
accz=zin ;
background(200) ;
g.draw() ;
/* Message has 13 bytes, 2 header bytes, one long, 3 ints and a final byte
* Note: that is Arduino long and int ( 32 and 16 bits ?? )
int C1=255 ; // initial string is FF FE
int C2=254 ;
void serialEvent( Serial p )
//long numchar=p.available() ;
//println("numchar is "+numchar );
int attempt=0 ;
while ( p.available() >= 14 )
int i1=p.read() ; // returns int 0 to 255 if a byte is there otherwise -1
attempt++ ;
if ( i1 == C1 )
if ( attempt > 1 ) println("matched first char at attempt "+attempt );
int i2=p.read() ;
if ( i2 == C2 )
// ten data bytes and a check byte we
// don't bother to check
int numread=p.readBytes( inbuf ) ;
if ( numread != 12 ) println("matched second char, numread = "+numread ) ;
if ( 1== 2 ) // list the hex bytes
for ( int jj=0 ; jj<numread ; jj++ )
print(hex(inbuf[jj])+" ");
println();
boolean trailergood=true ;
if ( numread >= 11 ) // check the trailer character
if ( inbuf[10] != 0x0024 )
println("Got bad trailer character "+hex(inbuf[10]) );
trailergood = false ;
// data for ints and longs comes in least significant byte first
if ( numread >= 10 )
long temp=0 ;
temp += ( inbuf[3] & 0x00FF ) ;
temp <<= 8 ;
temp += ( inbuf[2] & 0x00FF ) ;
temp <<= 8 ;
temp += ( inbuf[1] & 0x00FF ) ;
temp <<= 8 ;
temp += ( inbuf[0] & 0x00FF ) ;
miltime = temp ;
int tem=0 ;
tem = (( inbuf[5] & 0x00FF ) << 8 ) + (inbuf[4]&0x00FF) ;
xin = tem ;
tem=0 ;
tem = (( inbuf[7] & 0x00FF ) << 8 ) + (inbuf[6]&0x00FF) ;
yin = tem ;
tem=0 ;
tem = (( inbuf[9] & 0x00FF ) << 8 ) + (inbuf[8]&0x00FF) ;
zin = tem ;
println("Got data time="+miltime+" "+xin+" "+yin+" "+zin) ;
ofile.println(miltime+" "+xin+" "+yin+" "+zin );
ofile.flush() ;
return ;
// didn't match the second character, so the first character match was a dud
// continue the while loop until we find a match or there are insufficient
// characters for a message
println("looking for second header char, got "+hex(i2)+" attempt= "+attempt) ;
// continue the loop until we find the first key byte,
// or there are less than 13 bytes so no complete message is available
println("looking for first header char, got "+hex(i1)+" attempt= "+attempt) ;
// println("serialEvent() ending, didnt get data");
