Hi guys, MuxShield consist of 48 analog input that isolated with I/O1, I/O2 and I/O3 with 16 input each.
with I/O3 i can received my analog input fine without any issue.
The issue is if i tried to use two lane with is I/O2 and I/O3.
Here is the example code that is running fine.
/*This example shows how to use the Mux Shield for a combination of
analog inputs, digital inputs, and digital outputs.
#include <MuxShield.h>
//Initialize the Mux Shield
MuxShield muxShield;
muxShield.setMode(3,ANALOG_IN); //set I/O 3 as analog input
Serial.begin(19200);
//Arrays to store input values
//Read analog inputs on IO3
const int analog1 = muxShield.analogReadMS(3,14); //IO3, pin 14
const int analog2 = muxShield.analogReadMS(3,15); //IO1, pin 15
//Print the results
Serial.print("analog1: ");Serial.print(analog1);Serial.print('\t');
Serial.print("analog2: ");Serial.print(analog2);Serial.println();
Output was great without any issue.
Here is the bad example:
muxShield.setMode(2,ANALOG_IN);
const int analog1 = muxShield.analogReadMS(2,14); //IO3, pin 14
//Print the results
Output with both input connected to GND
i tried using I/O1 still same thing.. is this related to the code or the hardware configuration? i havent touch any jumper on the bottom.. it come still standart as it is.
Thank you!
