Hi guys
I've read about a million different posts and sketches on doing this, but I still can't get my head around it.
I need a countdown timer for about 20 seconds that shows the 10ths of seconds after a decimal point, initiated by a button press. The timer counts down to zero and then lights up an LED. Pressing the button again resets the timer.
I found a sketch that works for me, but when I press the button it starts, but then if the button is released the timer resets.
My idea is to have a momentary switch begin the countdown (press once and release and the timer starts), then at 000.0 an LED lights up. Then the button can reset the countdown back to 20 seconds upon a second press. There is probably a simple fix but my brain is being dumb.
Using an Uno, with the common cathode 4-digit, 7-segment display SH5461AS. Using Windows, Arduino IDE version 1.0.6
Attached is the setup. Code below. Thanks for any help!
Stop-Watch
Push button re-start the timer
int a = 5;
int b = 6;
int c = 7;
int d = 8;
int e = 9;
int f = 10;
int g = 11;
int p = 0;
int d4 = 4;
int d3 = 3;
int d2 = 2;
int d1 = 1;
int LaunchLED = A5; //light up led for rocketlaunch
int startStopReset = 13; //button pin
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState =0; // previous state of the button
// This variable gets toggled either high or low each time the button is pressed.
// In other words, this variable changes states with each button press.
bool pressed = true;
int buttonpress;
long n = 30000; //start time: 300000 = 30s seconds
int x = 100;
int del = 55;
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(p, OUTPUT);
//launch mode light output
pinMode(LaunchLED, OUTPUT);
pinMode(startStopReset, INPUT); //button input
//digitalWrite(startStopReset, HIGH);
clearLEDs();
pickDigit(1);
pickNumber((n/x/1000)%10);
delayMicroseconds(del);
clearLEDs();
pickDigit(2);
pickNumber((n/x/100)%10);
clearLEDs();
pickDigit(3);
dispDec(3);
pickNumber((n/x/10)%10);
clearLEDs();
pickDigit(4);
pickNumber(n/x%10);
n--; //'n++' for stopwatch
if (digitalRead(13) == LOW)
n = 20000; //re-start time: 200000 = 20s seconds
void pickDigit(int x)
digitalWrite(d1, HIGH);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
switch(x)
case 1:
digitalWrite(d1, LOW);
case 2:
digitalWrite(d2, LOW);
case 3:
digitalWrite(d3, LOW);
digitalWrite(p, HIGH); //new
default:
digitalWrite(d4, LOW);
void pickNumber(int x)
switch(x)
default:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
void dispDec(int x)
digitalWrite(p, LOW);
void clearLEDs()
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, LOW);
void zero()
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
void one()
void two()
digitalWrite(g, HIGH);
void three()
void four()
void five()
void six()
void seven()
void eight()
void nine()
