Ok, here you go. Most of it isn't relevant to my question
#include <AccelStepper.h>
#include <Servo.h>
#include "avdweb_AnalogReadFast.h"
// stepper variables
const int enaPin = 0;
const int dirPin = 1;
const int stepPin = 2;
int msMultiplier = 2;
int spr = 200 * msMultiplier;
int speed;
int maxSpeed = 7500; // 7500 fastest allowable
bool isRunning = false;
int currentPos;
AccelStepper stepper = AccelStepper(1, stepPin, dirPin);
// servo variables
Servo servo1;
Servo servo2;
const int servo1Pin = 10;
const int servo2Pin = 12;
const int minPulseWidth = 544;
const int maxPulseWidth = 2400;
const int midPos = 34 + (156 - 32) / 2;
int servoPos = 0;
int servoAmp = 100;
// encoder variables
const int channelAPin = 9;
const int channelBPin = 8;
const int indexPin = 7;
int encoder_pos = 0;
bool start_homing = false;
//int error = 0;
// other variables
#define stepPotPin A5
#define ampPotPin A4
const int limitPin = 6;
bool limit_hit = false;
bool homed = false;
// position variables
int upperEncoderBound = 44700;
int lowerEncoderBound = 0;
int stepsToTop = 3180;
bool outsideBounds = false;
long startTime = 0;
long endTime = 0;
int amplitude;
//int ampInSteps = 50 * (137 / 10);
int ampInSteps = 288 * 2;
int ampInTicks = amplitude * 78.7401;
pinMode(enaPin, OUTPUT);
digitalWrite(enaPin, LOW);
pinMode(dirPin, OUTPUT);
pinMode(channelAPin, INPUT_PULLDOWN);
pinMode(channelBPin, INPUT_PULLDOWN);
pinMode(indexPin, INPUT_PULLDOWN);
pinMode(limitPin, INPUT);
digitalWrite(limitPin, LOW);
pinMode(stepPotPin, INPUT);
pinMode(ampPotPin, INPUT);
attachInterrupt(digitalPinToInterrupt(channelAPin), encode, CHANGE);
attachInterrupt(digitalPinToInterrupt(indexPin), indexHit, RISING);
attachInterrupt(digitalPinToInterrupt(limitPin), limit_switch_hit, FALLING);
//attachInterrupt(digitalPinToInterrupt(stepPotPin), setSpeed, CHANGE);
servo1.attach(servo1Pin, minPulseWidth, maxPulseWidth);
servo2.attach(servo2Pin, minPulseWidth, maxPulseWidth);
home();
int calculateError(){
int ticksLost = 0;
if(encoder_pos > upperEncoderBound / 2){
ticksLost = upperEncoderBound - encoder_pos;
}else{
ticksLost = 0 - encoder_pos;
return (ticksLost / 137) * 10;
void home(){
Serial.println("starting homing sequence");
servo1.write(midPos);
servo2.write(midPos);
digitalWrite(dirPin, LOW);
while(limit_hit != true){
//single_step(1);
runAtSpeed(2000, 1);
digitalWrite(dirPin, HIGH);
while(encoder_pos < upperEncoderBound){
//single_step(1);
runAtSpeed(2000, 0);
Serial.println(ampInTicks);
stepper.setCurrentPosition(0);
Serial.println("homed");
homed = true;
void limit_switch_hit(){
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
if(interrupt_time - last_interrupt_time > 50){
Serial.println("limit hit");
if(limit_hit == true){
//stepper.stop();
outsideBounds = true;
encoder_pos = 0;
limit_hit = true;
last_interrupt_time = interrupt_time;
void encode(){
int a = digitalRead(channelAPin);
int b = digitalRead(channelBPin);
if(a == HIGH){
if(b == LOW){
encoder_pos++;
}else{
encoder_pos--;
}else{
if(b == LOW){
encoder_pos--;
}else{
encoder_pos++;
if((encoder_pos > upperEncoderBound + 500 || encoder_pos < 150) && homed == true){
Serial.println("encoder detects out of bounds");
//stepper.stop();
void indexHit(){
Serial.println("index");
void index(){
if(interrupt_time - last_interrupt_time > 200 && limit_hit == true){
encoder_pos = 0;
if(start_homing == false){
stepper.stop();
Serial.println("Stepper homed.");
start_homing = true;
}else{
homed = true;
Serial.println("at index");
unsigned long lastStepTime;
void runAtSpeed(unsigned long stepInterval, int dir){
unsigned long time = micros();
if(time - lastStepTime >= stepInterval){
if(dir == 1){
currentPos += 1;
}else{
currentPos -= 1;
stepper.step(currentPos);
lastStepTime = time;
int getSpeed(){
int potVal = analogReadFast(stepPotPin);
if(potVal == -1){
isRunning = false;
return 0;
}else{
isRunning = true;
return map(potVal, 0, 932, 2900, 10000); // tweak the min and max output values so that pot always maps to 0.5 Hz (2900) -> 3.0 Hz ()
int getAmplitude(){
int amp = map(analogReadFast(ampPotPin), 0, 932, 50, 200) * 137 / 10; // * (10 / 137) * 2;
return amp;
int stepError(){
return (upperEncoderBound - encoder_pos) * 10 / 137;
int cycles = 0;
int error = 0;
float actualHz;
int servoArray[686 * 2];
int servo2Array[686 * 2];
void createServoArray(int amp){
Serial.println("creating servo array.");
int index = 0;
for(int i = -amp; i < 0; i++){
//Serial.println(String(i) + ", doing first half");
if(i < (-amp / 2)){
servoArray[index] = map(i, -amp, -amp / 2, midPos, (midPos + servoAmp / 2));
//Serial.println("to amp, " + String(map(stepper.distanceToGo(), -amplitude, -amplitude / 2, midPos, (midPos + servoAmp / 2))));
}else{
//Serial.println("to 0, " + String(map(stepper.distanceToGo(), -amplitude / 2, 0, (midPos + servoAmp / 2), midPos)));
servoArray[index] = map(i, -amp / 2, 0, (midPos + servoAmp / 2), midPos);
index++;
for(int i = amp; i > 0; i--){
//Serial.println("second half");
if(i > (amp / 2)){
//Serial.println(String(index) + ", " + String(map(i, amplitude, amplitude / 2, midPos, (midPos - servoAmp / 2))));
servoArray[index] = map(i, amp, amp / 2, midPos, (midPos - servoAmp / 2));
//Serial.println(map(stepper.distanceToGo(), amplitude, amplitude / 2, midPos, (midPos - servoAmp / 2)));
}else{
//Serial.println(map(stepper.distanceToGo(), amplitude / 2, 0, (midPos - servoAmp / 2), midPos));
servoArray[index] = map(i, amp / 2, 0, (midPos - servoAmp / 2), midPos);
index++;
for(int i = 0; i < amplitude * 2; i++){
servo2Array[i] = map(servoArray[i], midPos - servoAmp / 2, midPos + servoAmp / 2, midPos + servoAmp / 2, midPos - servoAmp / 2);
// for(int i = 0; i < amplitude * 2; i++){
// if(i == amplitude){
// Serial.print("middle, ");
// Serial.print(String(servoArray[i]) + ", ");
int lastPos1;
int lastPos2;
void writeServos(int pos1, int pos2){
if(pos1 != lastPos1){
servo1.write(pos1);
if(pos2 != lastPos2){
servo2.write(pos2);
lastPos1 = pos1;
lastPos2 = pos2;
int lastAmplitude;
//amplitude = getAmplitude(); //288 * 2;
amplitude = 686;
if(amplitude != lastAmplitude){
createServoArray(amplitude);
speed = getSpeed();
//speed = 4000;
int accel = speed / 1.15; // dont change this scalar
int i = 0;
long cycleStartTime = micros();
stepper.moveTo(-amplitude);
Serial.println("moving to -" + String(amplitude));
//setSpeed();
stepper.setMaxSpeed(speed);
stepper.setAcceleration(accel);
int lastPosition = 0;
if(!outsideBounds){
while(stepper.distanceToGo() < 0 && !outsideBounds){
//Serial.println(stepper.distanceToGo());
// if(stepper.distanceToGo() < (-amplitude / 2)){
// writeServos(map(stepper.distanceToGo(), -amplitude, -amplitude / 2, midPos, (midPos + servoAmp / 2)));
// //Serial.println("to amp, " + String(map(stepper.distanceToGo(), -amplitude, -amplitude / 2, midPos, (midPos + servoAmp / 2))));
// }else{
// //Serial.println("to 0, " + String(map(stepper.distanceToGo(), -amplitude / 2, 0, (midPos + servoAmp / 2), midPos)));
// writeServos(map(stepper.distanceToGo(), -amplitude / 2, 0, (midPos + servoAmp / 2), midPos));
//writeServos(servoArray[i]);
if(stepper.currentPosition() != lastPosition){
writeServos(servoArray[i], servo2Array[i]);
i++;
lastPosition = stepper.currentPosition();
//stepper.currentPosition();
stepper.run();
//delayMicroseconds(5000);
stepper.stop();
stepper.runToPosition();
stepper.moveTo(0 + error);
Serial.println("moving to 0");
while(stepper.distanceToGo() > 0 && !outsideBounds){
// if(stepper.distanceToGo() > (amplitude / 2)){
// writeServos(map(stepper.distanceToGo(), amplitude, amplitude / 2, midPos, (midPos - servoAmp / 2)));
// //Serial.println(map(stepper.distanceToGo(), amplitude, amplitude / 2, midPos, (midPos - servoAmp / 2)));
// }else{
// //Serial.println(map(stepper.distanceToGo(), amplitude / 2, 0, (midPos - servoAmp / 2), midPos));
// writeServos(map(stepper.distanceToGo(), amplitude / 2, 0, (midPos - servoAmp / 2), midPos));
i++;
stepper.run();
// cycle end print lines
stepper.stop();
cycles++;
error = stepError();
actualHz = 1 / ((micros() - cycleStartTime) / 1e6);
Serial.println("cycle: " + String(cycles));
Serial.println("hz: " + String(actualHz, 6));
Serial.println("encoder pos: " + String(encoder_pos) + ", step error: " + String(error));
Serial.println("");
lastAmplitude = amplitude;
i = 0;
