need help beginner for aurdino
i am using aurdino and accelerometer
attached is the coding for accelerometer
after knowing the angle, i would like to use the angle for this equation:
cos(teta) = cos (delta)cos (alpha)cos(omega) + sin(delta)sin(alpha)
where the teta is the z and alpha is x
omega = 15.(t-12)
i wan to know de value of delta..
how do i write the code?
pls help me.
accelerometer_2.ino (1.48 KB)
Where did you get this "equation" ?
It looks very familiar to a trig idenity. Do you want to solve the problem or do you want the arduino to solve the problem. Is that suposed to be (cos) Theta
Ya think ?
Its been a while like two years but I don't even see how if you knew how to write the code for this could help you in the arduino field. I guess there is much this grasshopper needs to learn.
This is a homework assignment if ever there was one...
Ok, what is the angle ?
cos(z) = cos (delta)cos (x)cos(omega) + sin(delta)sin(alpha)
omega = 15.(t-12)
So ? You have the equation.
Why don't you write the code ?
http://arduino.cc/en/Reference/Cos
raschemmel:
I think this is more a maths question than a coding one, since he has yet to isolate delta from the equation
which if you know the other angles and therefore their sins and cosines reduces to
p = cos (delta) qr + sin(delta)s
But my trig skills are a little rusty to solve that for delta unfortunately.
Hi, what is the value of t in the omega equation.
Or are you looking for delta= function(omega, alpha, teta)
delta= function(t, alpha, teta)
In any case this is all maths trig, identity, I'd be off to a tutor or lecturer to get some hints.
I used to have a sheet of identity formulas when I was in high school, ahhhhh yes those were the days.
Tom.......... :slight_smile:
PS, is this what you are trying to do?
http://www.esrl.noaa.gov/gmd/ozwv/dobson/papers/report6/appf.html
Hmmmh.....very astute Grasshopper....
Thankyou Master Po.
